发表于 2016-7-20 16:18:51
显示全部楼层
回复 11# 桃儿爷。
好久没有看论坛了,我来回答下。 该警告提醒有些晶体管的引脚没有连接。而为了求解的方便性,将那个端口连接上一个极大的电阻,这样做的好处是方便建立整个电路的求解矩阵。仅此而已。实际上如果你自己的晶体管电路如果都连接正确,基本不用管这个警告。
ADS官方解释如下:
In the case of a circuit with a wire that is missing, a message such as the following can appear in the Simulation/Synthesis Messages window during a simulation:
Warning detected by HPEESOFSIM during DC analysis "DC1".
Circuit as given has no unique solution.
A virtual resistance of 1 TOhms was added to each node. In the case of unconnected wires or pins, choose
Tools
Check Representation, then select
Open connections
and click
OK. All unconnected wires and components are highlighted, making them easily visible on the screen. Connect these to the correct circuit node. |
