查看: 8570|回复: 13
ADS Channsim不能用
发表于 2015-12-15 10:39:50 | 显示全部楼层 |阅读模式
channelsim 不能仿真,各位大侠有碰到过吗?怎么解决呢?
Simulation Messages
Error detected by hpeesofsim during circuit set up `ChannelSimTransient'.
    An attempt to use the Channelsim feature was made, and a valid
    Channelsim license is not available.  This software is not licensed for
    use with Channel simulations.
        FlexLM error message:
        Channel Simulator Element
        You do not have a license to run this feature.
        Below is a list of products that contain this feature:
        W2250BT ADS Inclusive
        W2250BP ADS Inclusive
发表于 2016-6-16 10:12:17 | 显示全部楼层
解决了吗?
我也遇到了同样的问题,请问是怎么解决的?
发表于 2016-6-16 12:11:28 | 显示全部楼层
add the following lines to your license file.
change 112233445566 with your hostid.
FEATURE sim_channel agileesofd 2015.1 31-dec-2050 88 VENDOR_STRING="112233445566 : GBZBNJV GRFDGPJ WELDCYP BHAUBBO WUIDLJV HYMDIBJ TYMYMXU RJ" HOSTID=112233445566 ISSUER="Pizote Azure" SIGN="0248 375D C285 29F0 9898 859B 8717 0DD0 BBF4 FBAC 9A00 8290 6835 E3B2 B38C 49B3 E72C 30FC 398E D7FD 4B01"
FEATURE e_sim_trans_conv_pk8 agileesofd 2015.1 31-dec-2050 88 VENDOR_STRING="112233445566 : ELPDJAN GYHN1AO CTFGPHE ULXJOAM GOCRZDW SMSNWVZ UMJQ1LP VSONSDD HSOIWZO FDDJ" HOSTID=112233445566 ISSUER="Pizote Azure" SIGN="02FF 55AB D956 79F8 963E 58A1 EA5E 409B 0087 8A9D B802 9F49 A65B 1E88 7A15 8117 CE59 EEBE 8A48 7942 DC0E"
FEATURE b_ads_inclusive agileesofd 2015.1 31-dec-2050 88 VENDOR_STRING="112233445566 : UQHKXFP AQCOTQN LFDDJFR IPUCZLM DJYBBHM WYYNBHH EKYANVH HUJJOLS EFRDA" HOSTID=112233445566 ISSUER="Pizote Azure" SIGN="0011 2828 F273 2374 848F 646A 40C4 DFDD FE4E 7674 7E02 43B6 4B66 29AA AAC0 1C9C 84D6 AEDE 65A0 5989 371A"
发表于 2016-6-20 19:22:36 | 显示全部楼层
谢谢mamdali, 不过还是不管用
        W2030UT EEsof University Bundle time-based  license
发表于 2016-6-21 20:15:15 | 显示全部楼层
也遇到同样的问题,求助
发表于 2016-6-21 20:23:25 | 显示全部楼层
@mamdali  谢谢分享,加入这个之后就可以用了,非常感谢
发表于 2016-7-1 11:18:37 | 显示全部楼层
E8900ECS Emergency Codeword System (ECS) ADS RFDE EMDS GG AMDS
E8900PE ADS Premier Student License
W2130UT EEsof University Bundle with EMPro
W2130UE EEsof University Bundle with EMPro Student License
W2030UE EEsof University Bundle time-based Student License
E8900PN ADS Premier Network University
E8900P ADS Premier University
W2200F ADS All Inclusive
W2130UX UNIVERSITY DONATION (EESOF INCLUSIVE)
W2030UX EESOF EDA MULTI-PRODUCT DONATION BUNDLE
E8900PX UNIVERSITY DONATION(ADS/PREMIER)
E8900PP ADS Premier University Donation
W2030UU EEsof University Bundle time-based  license
W2130UU EEsof University Bundle with EMPro
E8900U ADS Standard University
E8900UN ADS Standard Network University
E8900UE ADS Standard Student License
E8900UX UNIVERSITY DONATION (ADS)
E8900UP ADS University Donation
W2320EP ADS Advanced Layout
W2320ET ADS Advanced Layout
有遇到过这个问题的吗?
发表于 2016-7-27 17:43:39 | 显示全部楼层
@mamdali  谢谢分享,加入这个之后就可以用了,非常感谢..这个问题在2016版也遇到了。。不知这段文字还有效吗???
发表于 2016-8-3 15:16:33 | 显示全部楼层
回复 6# maecho
你是怎么设置后能够使用的啊?我的还是不行,求指教...
发表于 2016-8-4 14:32:35 | 显示全部楼层
按照三楼大神的弄了后可以了,就是要注销一次,或者重启也可以
GMT+8, 2025-12-26 02:42 , Processed in 0.064651 second(s), 6 queries , Gzip On, Redis On.
