查看: 2308|回复: 1
[招聘] 固态硬盘+存储器-
发表于 2015-11-27 18:56:07 | 显示全部楼层 |阅读模式
产品工程师职位
关于memory 存储器和固态硬盘的
简历发 [url=mailtoffer@hi-talent.net]offer@hi-talent.net[/url]
JobTitle: Product Engineer
HiringDept: Flash Memory Product Eng
JobDescription
- Be responsible for packaged flash memorytest program development, units failure analysis and device issue debug
- Be responsible for NAND Product andPackage Qual / Rel tests setup / eFA / Action Plan.
- Providing correct test condition for thememory product and generate defined test flow for volume testing needs
- Product Evaluation DOE for Rel / DPPMimprovement and D/S and KGD Sort Yield improvement.
- Run the test time analysis to get alowest cost test method in order to reach short test time and high testingcoverage
- Define / improve testing method to dealwith new product introduced to mass production and marketing
- Deliver a world class throughput time onthe testing code development to reach the most effective way of sample deliveryTPT (ThroughPut Time)
- Work with multinational team to completeassigned projects in PDT (product development team) required time.
JobQualifications
- Electrical Engineering background with BSdegree needs 5-8 years experiences on memory testing
- Familiar with most advanced developmenttest program: ATL or wafer level test program coding
- Have knowledge on NOR/NAND or RAM testing
- Ability to troubleshoot, analyze complexproblems, multi-task and meet deadlines.
- Excellent English communication (writtenand verbal) and interpersonal skills
- Good team work, willing to learn, logicalthinking and pressure taken
- Good communication skills
System Engineering Manager SSD(固态硬盘)
Responsibilities:
? Provide system engineering leadership tolink system test, hardware, software, firmware, quality, FA, mechanical,electrical, and product engineering aspects of Solid-Disk-Drive manufacturing.
? Manage and provides technical guidance toproduct engineering, MFG test, FA and EMS management teams in China.
? Drive test process improvement, Yieldimprovement, hold lot disposition, cost reduction, capacity improvement, MRBmaterial disposition, failure analysis on low yield lots, qualification fail,QC fail, and RMA return
? Work closely with corporate R&D teamand CM to ensure smooth product transition
? Provide support to assembly &packaging engineering to identify process yield issues
? Work closely with operation to ensureshipment fulfillment
Requirements:
? Experience in system engineering andarchitecture for SSD, laptop or PC products.
? Experience or knowledge of storagearchitecture
? Good understand on IC component such asDDR, EEPROM, ASIC especially Flash memory
? Good understand of all aspects of systemtest including test, hardware, mechanical, electrical, system interfaces,firmware and software.
? Good Knowledge of SAS/SATA/PCI-e/USBinterfaces at both device and host level.
? Experience with SSD HW/SW testing atsystem and component levels.
? Experience in systems engineering designand debug; including traceability from the system level to component levels.
? Familiar with environmental stressscreening and testing that includes shock, vibration, and thermal cycling ofSSD and component level.
? Experience with C/C++, Visual Studio andothers.
Best Regards
Jane.Jin 金娟
Principal Consultant & General Manager @ Hi-Talent Consulting Co.,Ltd.
上海芯得企业管理咨询有限公司
上海芯相会企业管理咨询有限公司
Mob:            18502155252
E-Mail:          Jane-Jin@hi-talent.com
微信:       xinde_jane
QQ:             1600548210
Weibo:          http://weibo.com/u/1716864892
webside
www.hi-talent.cn
发表于 2016-5-12 16:32:33 | 显示全部楼层
顶一个,我也想涉足memory设计领域
GMT+8, 2025-12-17 00:40 , Processed in 0.016817 second(s), 7 queries , Gzip On, Redis On.
