查看: 3893|回复: 8
[求助],QRC安装问题,求大神指导
发表于 2015-11-17 15:19:38 | 显示全部楼层 |阅读模式
1447744268835.jpg   QRC安装启动就是这样,不知道哪里出了问题,求指导。  icfb 里面也有问题。
 楼主| 发表于 2015-11-17 15:28:17 | 显示全部楼层
IMG_20151117_185947.jpg 回复 1# _shanks  ASSURA 也是不行,应该是license 的问题,谁有可以使用QRC的license。麻烦分享一下。
 楼主| 发表于 2015-11-17 15:43:57 | 显示全部楼层
自己顶
 楼主| 发表于 2015-11-17 19:02:20 | 显示全部楼层
求QRC可以使用的license。
发表于 2016-5-15 19:45:17 | 显示全部楼层
楼主问题解决了吗?  我安装完EXT QRC 在Cadence上没有找到软件啊
发表于 2016-5-17 14:00:51 | 显示全部楼层
回复 4# _shanks
    请教一下,为什么我安装完QRC后,在virtuoso找不到QRC ,直接运行qrc会出现和你一样的问题。
 楼主| 发表于 2016-6-1 21:33:55 | 显示全部楼层
回复 6# icccliu
    没有解决哈
发表于 2016-6-1 22:21:49 | 显示全部楼层
回复 7# _shanks
1. The log message printed by type >qrc is right. cuz you do not given proper command file,
        so qrc has nothing to do.
2. You can try to run $qrcui to start GUI mode, which should run w/o problem.
3. You license seems does not have features for QRC, you can dig into license file and search for "QRC",
     If there no certain features like "Virtuoso_QRC_xxxx" and "QRC_xxx", you should have to find another one.
4. P.S, make sure you have set right OA_HOME, (recommended to direct the one inside EXT/QRC installation directory)
    QRC needs library file inside OA home directory.
 楼主| 发表于 2016-6-30 10:27:37 | 显示全部楼层
回复 8# mipsgreen
   好的,我试试,谢谢你
GMT+8, 2025-12-23 13:56 , Processed in 0.021243 second(s), 4 queries , Gzip On, Redis On.
