查看: 19037|回复: 29
[资料] hspice meas 输出数据转csv格式以及最大/最小值统计的perl脚本
发表于 2015-11-4 19:42:01 | 显示全部楼层 |阅读模式
一个perl脚步, 可以把hspice meas的数据转换成csv格式, 并且同时统计各个corner输出的最大和最小值.
用法: meas2csv meas_file.mt0 out_file.csv
meas2csv.rar (1.1 KB , 下载次数: 301 )
发表于 2015-11-4 20:47:23 | 显示全部楼层
kankan
发表于 2015-11-4 23:10:14 | 显示全部楼层
非常感谢提供!
发表于 2015-11-5 09:14:57 | 显示全部楼层
谢谢分享!
 楼主| 发表于 2015-11-5 11:39:14 | 显示全部楼层
发现HSPICE输出meas数据的格式可以用option来改变. 以下是帮助文档
.OPTION MEASFORM
Enables writing of measurement output files to Excel or HSIM formats, as well
as the traditional HSPICE *.mt# format.
Syntax
.OPTION MEASFORM=0|1|2|3
Default 0
Description
This option allows specification of file formats other than the traditional HSPICE
*mt#, *ms#, and *ma# measure output files to include Excel or HSIM file
formats.
■ 0: Writes measure file in traditional default HSPICE output style. (Example
1)
■ 1: Writes space-separated style which can be imported as data into Excel
and Microsoft products (requires manual steps in Excel). (Example 2)
■ 2: Writes he HSIM style in name=value format. Easy to read, but difficult to
import into standard post-processing tools. (Does not work for *.mc?# files
[see value 3 below] and defaults to HSPICE default output style). (Example
3)
■ 3: Writes the comma separated style with suffix *.csv and this format
includes *m?# and *.mc?# files.This style and suffix is understood by
Windows to be an Excel file and can be opened directly in Excel by doubleclicking the file name. (Example 4)
发表于 2016-1-27 17:31:03 | 显示全部楼层
回复 5# david_reg
    谢谢您的帮助 困扰我很久的问题 现在解决了  太感谢你了!
发表于 2016-1-27 17:37:32 | 显示全部楼层
niubility
发表于 2016-3-31 22:01:50 | 显示全部楼层
thank you
发表于 2017-3-28 10:50:44 | 显示全部楼层
感谢分享~~~~
发表于 2017-3-28 22:20:22 | 显示全部楼层
感谢分享~~~~
GMT+8, 2025-10-17 03:37 , Processed in 0.018064 second(s), 4 queries , Gzip On, Redis On.
