查看: 7724|回复: 23
[原创] Voltage regulators for Microprocessors
发表于 2015-10-13 19:41:13 | 显示全部楼层 |阅读模式
1 Introduction ................................................................ 1
1.1 The Microprocessor Load .............................................. 1
1.2 The Microprocessor Power Supply ..................................... 9
1.2.1 Voltage Regulator (VR) Specifications ......................... 9
1.2.2 Basic Circuit Topology ........................................ 13
1.2.3 System Architecture ........................................... 15
1.2.4 Semiconductor Power Devices ................................ 17
1.2.5 Gate Driving Schemes ......................................... 22
1.2.6 Filters .......................................................... 25
1.2.7 Control Systems ............................................... 31
1.2.8 Packaging and Integration ..................................... 39
1.2.9 Commercial Voltage Regulators .............................. 41
1.2.10 Survey on Power MOSFET Models
for Circuit Simulations ........................................ 45
1.3 Objectives of the Thesis ............................................... 48
1.4 Methodological Approach ............................................. 49
1.5 Thesis Outline ......................................................... 53
References . ................................................................. 54
2 Model Level 0: Switching Behavior of Power MOSFETs ............. 67
2.1 Power MOSFET Model for Circuit Simulations ...................... 68
2.1.1 Model Structure and Implementation ......................... 69
2.1.2 Model Data Acquisition ....................................... 75
2.2 Switched Converter Test Board ....................................... 90
2.2.1 Gate Driver .................................................... 91
2.2.2 Input/Output Filters ............................................ 94
2.2.3 PCB Layout Impedance Characterization ..................... 95
2.3 Switched Converter Simulation Setup ................................. 97
2.4 Model Validation ..................................................... 101
2.5 Analysis of Switching Behavior ...................................... 112
2.5.1 Loss Breakdown ............................................... 113
2.5.2 Influence of the Body-Effect on Switching Losses ........... 122
2.5.3 Loss Analysis of a Multichip Module . ........................ 128
References . ................................................................ 131
3 Model Level 1: Piecewise Linear Analytical Switching Model ....... 133
3.1 Modeling Approach ................................................... 134
3.2 Hard-Switching Model ............................................... 141
3.2.1 Leading Edge Transition ...................................... 143
3.2.2 Falling Edge Transition ........................................ 147
3.2.3 Leading and Falling Edge Transitions Tradeoffs ............. 150
3.3 Leading Edge Switched-Node Ringing .............................. 155
3.3.1 Charging Loss .................................................. 159
3.3.2 Overvoltage Stress ............................................. 161
3.3.3 Avalanche Breakdown ......................................... 162
3.3.4 Reverse Recovery .............................................. 166
3.3.5 Gate Bounce ................................................... 169
3.4 Falling Edge Ringing Transition ..................................... 180
3.4.1 Charging Loss .................................................. 184
3.4.2 Overvoltage Stress ............................................. 188
3.4.3 Avalanche Breakdown ......................................... 190
3.5 Gate Driving .......................................................... 190
3.6 Model Validation ..................................................... 191
References . ................................................................ 195
4 Model Level 2: Power Loss Model ...................................... 197
4.1 Power MOSFET Losses .............................................. 198
4.1.1 Half-Bridge Charging Loss .................................... 198
4.1.2 Gate Charging Loss ............................................ 199
4.1.3 Load Current Hard-Switching ................................. 201
4.1.4 Load Current ON Conduction ................................. 205
4.2 Losses of Gate Drive Switches ....................................... 207
4.3 Filter Loss ............................................................. 208
4.4 PCB Loss ............................................................. 209
4.5 Model Validation ..................................................... 210
References . ................................................................ 212
Voltage Regulators for Next Generation Microprocessors-Springer (2010).rar (11.73 MB , 下载次数: 485 )
发表于 2015-10-14 07:37:05 | 显示全部楼层
KanKan
发表于 2015-10-14 08:21:09 | 显示全部楼层
非常感谢,您的客服真是超级牛!赞,6星!呵呵呵。
发表于 2015-10-14 16:51:41 | 显示全部楼层
比较合适板级设计
发表于 2015-10-15 20:20:43 | 显示全部楼层
kankan
发表于 2015-10-15 20:21:31 | 显示全部楼层
zhichiyixia
发表于 2015-10-15 22:56:23 | 显示全部楼层
非常感谢提供!
发表于 2015-10-19 13:01:54 | 显示全部楼层
回复 1# Golden_Hawk
    谢谢分享
发表于 2015-10-28 03:45:46 | 显示全部楼层
感謝大大的分享
发表于 2015-10-28 17:32:44 | 显示全部楼层
kankan
GMT+8, 2025-12-15 18:48 , Processed in 0.031292 second(s), 8 queries , Gzip On, Redis On.
