查看: 4076|回复: 1
生命医学软件FEI.Amira.v6.0.1.win32 64 Linux64 MacOSX -- 发现者软件网
发表于 2015-10-10 16:35:05 | 显示全部楼层 |阅读模式
FEI.Amira.v6.0.1.Win32_64 2DVD FEI.Amira.v6.0.1.MacOSX 1DVD FEI.Amira.v6.0.1.Linux64 1DVD 从重构的几何形状或任何导入的三维数据,包括时间序列,Amira提供了广泛的可视化技术和交互式操作能力。 通过一套全面的3D后期处理工具,它提供了一个高度灵活、强大的3D可视化和分析平台。
HEEDS.MDO.2015.04.2.Win32_64.&.Linux64 3CD线性分析多学科设计优化工具
HEEDS MDO 支持与目前几乎所有的CAE应用软件接口,主要有的Abaqus/ansys/excel/ls-dyna/nastran/ug nx/solidworks/ STAR- CCM+/adams/matlab等。它可以协助使设计优化过程自动化,还能调用多种软件工具进行前处理、后处理、分析计算和多学科优化等。 除此之外,HEEDS MDO 还提供了一种通用的接口生成ASCII格式的输入输出文件,从而可以连接所有商业或者私有CAE工具。 用户可以利用HEEDS MDO 软件进行众多的分析,快速确定优化空间,省去了众多的试验费用及时间;从大量的模型参数中提取出敏感参数进
Mosek.ApS.Mosek.v7.1.Win32_64
Mosek ApS Mosek v7.x (Win/Mac/Lnx) | 193 Mb (Total) MOSEK is a tool for solving mathematical optimization problems such as: linear programs, quadratic programs, conic problems, mixed integer problems. The MOSEK optimization software is designed to solve large-scale mathematical optimization problems. MOSEK main features are listed below. For additional questions, contact our support or browse the online documentation. Problem types MOSEK can solve - Linear - Conic quadratic - Semidefinite (Positive semidefinite matrix variables) - Quadratic and quadratically constrained - General convex nonlinear - Mixed integer linear, conic and quadratic Technical highlights - Problem size limited only by the available memory. - Interior-point optimizer with basis identification. - Primal and dual simplex optimizers for linear programming. - Highly efficient presolver for reducing problem size before optimization. - Network-simplex for problems with network flow structure. - Branch&bound&cut algorithm for mixed integer problems. Strengths of MOSEK The strong point of MOSEK is its state-of-the-art interior-point optimizer for continous linear, quadratic and conic problems. Parallel capabilities The interior-point optimizer is capable of exploiting multiple CPUs/cores. A concurrent optimizer is available that makes it possible to solve one problem with different optimizers simultaneously. The default mixed integer optimizer is parallelized and is run-to-run deterministic. Other features of MOSEK Reads and writes industry standard formats such as the MPS and LP formats. Includes tools for infeasibility diagnosis and repair. Sensitivity analysis for linear problems.
发表于 2024-5-20 12:53:25 | 显示全部楼层
thanks
GMT+8, 2025-12-22 23:12 , Processed in 0.017749 second(s), 6 queries , Gzip On, Redis On.
