在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2565|回复: 1
[求助] Hspice call verilogA 理想dac 失败
发表于 2015-10-7 12:07:13 | 显示全部楼层 |阅读模式
Hspice call verilogA 理想dac 失败 ,
voltage define ,
module ideal_dac(in,out);
input [0:dac_size-1] in;
output out;
voltage in,out;  ==> error
parameter real dac_size = 7 from (1:inf); parameter vth = 2.5; parameter real trise = 0 from [0:inf); parameter real tfall = 0 from [0:inf); real code; integer pow2 [0:dac_size]; analog begin   @(initial_step)     for (i=0;i<=dac_size;i=i+1) pow2 = pow(2,i);   code = 0;   for (i=0;i<dac_size;i=i+1)     code = code + (V(in) > vth) ? pow2 : 0;   V(out) <+ transition(code/pow2[dac_size],0,trise,tfall); endendmodule
and modify
但是 把输出入改  electrical 一样有问题
Error: Reference to undefined discipline 'electrical'.
还有某些版本 windows hspice 好像一跑veriloga 会当掉
 楼主| 发表于 2015-10-7 14:43:08 | 显示全部楼层
回复 1# andy2000a
   I find the problem .
nature electrical 被定義在  disciplines.vams , 但是   disciplines.vams   就算直接 include 也無法在 hspice2009  下使用 ,
不過 跑adc.va examples 在  hspice 2009 work , 但是會再   hspice 2013  crash ..
再試過一些方式 發現了 .
1. hspice win 2009 can not use voltage  electrical   . but in hspice 2013 use electrical is work,
   voltage not work .
but simulation very slow  ? crash again  ??  怪怪的 ..
2. sometime hspice 2013 run  include verilog-A will crash but hspice 2009 not .
  如 dca.va bit define 相衝突下  hspice2013 直接 當掉 ..
GMT+8, 2025-4-5 16:55 , Processed in 0.020263 second(s), 9 queries , Gzip On, MemCached On.
