查看: 3733|回复: 2
PCI,PCI桥,PCIe最新技术及方案
发表于 2007-5-21 14:19:50 | 显示全部楼层 |阅读模式
pericom是美国一家上市公司
我们代理其PCI,PCI桥,PCIe,及HDMI SWITCH高清开关(产品列表其后附)
有意者请与我司联系:李小姐,LISA
北京泰宇凯达科技有限公司
MSN:
lisa_neimeng@hotmail.com
E-mail:lisa.li@kada.com.cn
Skype:lisa.li22
电话:010-82884830/1/2/3-815(分机)
传真:010-82884829
网址:
www.kada.com.cn
我们公司是以下产品在中国大陆的总代理。
1.Davicom(台湾联杰公司的10/100M以太网接口芯片)
2.RDC(台湾金丽公司的RISC架构的CPU)
3.Pericom(HDMI接口芯片,PCI-e桥等)
4.Group-tek(RJ45隔离变压器)
5.Essense IP-PBX(提供Essense公司的IP-PBX完整解决方案)
6.AOS(Mosfet,DC-DC降压芯片)
Part NumberDescriptionSpeedWidthPortsLanesPinsPbFreePackage
PI7C21P1002-Port PCI-X to PCI-X Bridge133 MHz64-bit2n/a304YesCSBGA (NH304)
PI7C21P100B2-Port PCI-X to PCI-X Bridge133 MHz64-bit2n/a304YesCSBGA (NH304)
PI7C7300A3-Port PCI-to-PCI Bridge66 MHz32-bit3n/a272YesPBGA (NA272)
PI7C7300D3-Port PCI-to-PCI Bridge66 MHz32-bit3n/a272YesPBGA (NA272)
PI7C8140A2-Port PCI-to-PCI Bridge66 MHz32-Bit2n/a128YesQFP (MA128)
PI7C8148A2-Port PCI-to-PCI Bridge66 MHz32-bit2n/a160YesLFBGA (NB160)
PBGA (NJ160)
PI7C8148BAsynchronous 2-Port PCI Bridge66 MHz32-bit2n/a160YesLFBGA (NB160)
PBGA (NJ160)
PI7C8150A2-Port PCI-to-PCI Bridge66 MHz32-bit2n/a208, 256YesFQFP (MA208)
PBGA (ND256)
PI7C8150A-332-Port PCI-to-PCI Bridge33 MHz32-bit2n/a208, 256YesFQFP (MA208)
PBGA (ND256)
PI7C8150BAsynchronous 2-Port PCI Bridge66 MHz32-bit2n/a208, 256YesFQFP (MA208)
PBGA (ND256)
PI7C8150B-33Asynchronous 2-Port PCI Bridge33 MHz32-bit2n/a208, 256YesFQFP (MA208)
PBGA (ND256)
PI7C8150BIAsynchronous 2-Port PCI Bridge66 MHz32-bit2n/a208, 256YesFQFP (MA208)
PBGA (ND256)
PI7C8152A2-Port PCI-to-PCI Bridge66 MHz32-bit2n/a160YesMQFP (MA160)
PI7C8152BAsynchronous 2-Port PCI Bridge66 MHz32-bit2n/a160YesMQFP (MA160)
PI7C8152BIAsynchronous 2-Port PCI Bridge66 MHz32-bit2n/a160YesMQFP (MA160)
PI7C8154A2-Port PCI-to-PCI Bridge66 MHz64-bit2n/a304YesPBGA (NA304)
PI7C8154A-332-Port PCI-to-PCI Bridge33 MHz64-bit2n/a304YesPBGA (NA304)
PI7C8154BAsynchronous 2-Port PCI Bridge66 MHz64-bit2n/a304YesPBGA (NA304)
PI7C8154B-80Asynchronous 2-Port PCI Bridge66 MHz64-bit2n/a304YesPBGA (NA304)
PI7C8154BIAsynchronous 2-Port PCI Bridge66 MHz64-bit2n/a304YesPBGA (NA304)
PI7C9X110APCIe-to-PCI Reversible Bridge66MHz32-bit21160YesLFBGA (NB160)
PI7C9X130PCIe-to-PCI-X Reversible Bridge133MHz64-bit24256YesPBGA (ND256)
PI7C9X204044-port, 4-lane, PCIe Packet Switchn/an/a44208YesPBGA (ND208)
 楼主| 发表于 2007-5-21 14:29:31 | 显示全部楼层
HDMI switch开关产品表:
我司代理的PERICOM的高清开关SWITCH
HDMI 产品表:
-         Multiple Configuration Pericom active switch have a rich portfolio, (inpututput)
-         1:1 – PI3HDMI411AD – Good for side HDMI adapter
-         1:2 – PI3HDMI412AD – Good for Docking demux features
-         2:1 – PI3HDMI421AR – Good for 2 to 1 HDMI receiver solution
-         2:2 – PI3HDMI422AR – Good for true HDMI PBP/PIP features
-         3:1 – PI3HDMI341AR – Good for 3 ports HDMI solution with weak EQ scalar.
-         4:2 – PI3HDMI442AR – Good for 4 ports HDMI solution with true HDMI PBP/PIP features
发表于 2010-5-5 16:16:31 | 显示全部楼层
广而告之啊!
GMT+8, 2025-12-22 22:22 , Processed in 0.020285 second(s), 8 queries , Gzip On, Redis On.
