查看: 2391|回复: 1
[求助] altera的cyclone iv芯片编译时gxb模块无故pin冲突
发表于 2015-9-23 18:20:11 | 显示全部楼层 |阅读模式
我编译时出现如下error,可是我这几个pin都没使用,报错后pin planner 里面无故出现这样一个output:clk_diff~reserved_gnd_T7,以前使用gxb收发器编译时都没出现这种问题,求解决方法,谢谢!
Error (169330): T7 cannot be used in the design when M7 is used to drive a transceiver channel at or greater than 2.97 Gbps.
Error (169330): T8 cannot be used in the design when M7 is used to drive a transceiver channel at or greater than 2.97 Gbps.
Error (169330): V6 cannot be used in the design when M7 is used to drive a transceiver channel at or greater than 2.97 Gbps.
Error (169330): W8 cannot be used in the design when M7 is used to drive a transceiver channel at or greater than 2.97 Gbps.
Error (169330): AA4 cannot be used in the design when M7 is used to drive a transceiver channel at or greater than 2.97 Gbps.
发表于 2015-9-24 10:44:44 | 显示全部楼层
期待中.....................
GMT+8, 2025-12-14 14:08 , Processed in 0.018725 second(s), 7 queries , Gzip On, Redis On.
