查看: 2448|回复: 3
安装Hspice出现问题??
发表于 2015-9-13 21:48:53 | 显示全部楼层 |阅读模式
启动setup.sh时出现这个问题??我把里面的endif改成fi,还是不对,说是什么DISPILY,,啊啊啊,根不知道怎么设置,,cadence都装好了,,求各位大声解答啊
下面这是setup.sh的内容,,
  1. #! /bin/csh -f
  2. if ( ! $?DISPLAY ) then
  3.     echo ""
  4.     echo "Note: The DISPLAY environment variable is not set."
  5.     echo "      Set this variable to proceed with the graphical"
  6.     echo "      installation."
  7.     echo ""
  8.     exit 1
  9. endif
  10. set cmdpath = "$0"
  11. set cmd = "$cmdpath:t"
  12. if ( "$cmd" == "$cmdpath" ) then
  13.   set cddir = "."
  14. else
  15.   set cddir = "$cmdpath:h"
  16. endif
  17. set cddir_path = $cddir
  18. if ( $cddir_path == "." ) then
  19.   set cddir_path = `pwd`
  20. endif
  21. $cddir_path/installer -gui
    复制代码
发表于 2015-9-15 11:19:37 | 显示全部楼层
source setup.sh
 楼主| 发表于 2015-10-4 14:39:48 | 显示全部楼层
回复 2# phoenixson
    已经解决了,我把tar.Z放在windows里面解压的,所以文件损坏了,,应该要在linux里面解压。
不过谢谢了哈
 楼主| 发表于 2015-10-4 14:41:08 | 显示全部楼层
回复 3# geek112212
    应该执行csh setup.sh或者./setup.sh或者./installer -gui,而不是sh setup.sh
GMT+8, 2025-11-24 20:22 , Processed in 0.020679 second(s), 7 queries , Gzip On, Redis On.
