查看: 992|回复: 0
[招聘] 【NVIDIA上海社招】ASIC PD 后端工程师
发表于 2015-8-24 17:37:51 | 显示全部楼层 |阅读模式
一.公司简介
       NVIDIA (英伟达™)(www.nvidia.cn)公司(纳斯达克代码:NVDA)是全球视觉计算技术的行业领袖及GPU(图形处理器)的发明者。作为高性能处理器的GPU可在工作站、个人计算机、游戏机和移动设备上生成令人叹为观止的互动图形效果。公司在全球拥有超过8000名员工,总部在加利福尼亚州圣克拉拉。
工作地址:上海研发中心【上海申江路5709号(秋月路26号)矽岸国际2号楼】
二.投递方式
简历发送至HR(Yvette SHEN)邮箱:yvettes@nvidia.com;请注明来源及申请职位
三.职位详情
1. ASIC-PD Engineer/Senior ASIC-PD Engineer
Job Description:
The ASICPhysical Design engineer is a challenging and cutting-edge position. It hasresponsibility for a wide range of task, including full chip layout planning(partitioning, planning clock distribution and other structure, methodology),partition/full chip timing closure (primetime scripts, other tools, etc) andgate-level design of high-speed logic
Responsibilities:
RTL Analysis and Synthesis
Formal verification and netlist quality analysis
Physical Integration and early floorplan
Partition level and full chip level StaticTiming Analysis
Work in conjunction with Place and RouteEngineers to achieve timing closure for both partition level and full chiplevel
Develop custom timing scripts using tcl/primetimefor clock skew analysis, special circuits such as clock dividers, core logic<-> IO macros interfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
Cross talk Analysis
Develop and enhance entire physical design flowfrom frontend (pre-layout) to backend (post-layout) at both chip and blocklevel.
Develop scripts for performing ECO's.
Basic Requirements:
BS or MS in Electrical Engineering or ComputerScience
Above 3 years of relevant ASIC experienceideally with a focus in the physical integration/synthesis/formal and timing closure
Excellent scripts skills
Excellent written and verbal communicationskills in English
Ability to multiplex many issues, set priorities,and work in a team environment
Keep up to date with leading edge technologies
BestRegards,
YvetteShen
APACStaffing Team
NVIDIASHANGHAI
Building 2, No. 5709 ShenjiangRoad (No.26 Qiuyue Road)  201210.
Tel+(86 21) 61043660
yvettes@nvidia.com
GMT+8, 2025-12-28 14:32 , Processed in 0.018266 second(s), 5 queries , Gzip On, Redis On.
