查看: 5523|回复: 5
[求助] matlab仿真SAR ADC有效位
发表于 2015-8-17 15:35:55 | 显示全部楼层 |阅读模式
 楼主| 发表于 2015-8-17 15:36:56 | 显示全部楼层
就是感觉有效位数应该很接近10吧,然后SFDR不应该这么大啊,求大神们指导啊==
发表于 2015-8-19 15:17:43 | 显示全部楼层
sfdr这么大很正常,你可能仿的点数比较多,做DFT的点数多,
因为你仿的可能是理想AD
但有效位不够接近9位是有点问题,
细节不清看不清原因
 楼主| 发表于 2015-8-19 17:24:39 | 显示全部楼层
回复 3# sohubjb
   下面是代码中的Approx函数,我是网上搜的代码然后改动了一部分function [counter,thresholds]=Approx_2(input,nbit,f_bw,sr,f_s,v)
% input= input sample
% nbit=  number of converter bits
% f_bw=  DAC bandwidth [f_s]
% sr=    DAC slew-rate [V_fs/T_s]
% f_s=   normalized sampling frequency
%                global variables                 %
threshold(1,nbit+1)=0;  % threshold array
counter=0;              % converter decimal output
threshold(1)=0.5*v;       % 0 threshold
threshold(2)=0.5*v;       % first threshold
threshold_id=0.5*v;       % next ideal threshold
tau=1/(2*pi*f_bw);      % DAC output pole
in=input;
Tmax=1/(f_s*nbit);      % clock period
for i=2nbit+1)       % conversion cycle
    if i < 6                                                如果把这里的数字改大,出来的效果会更好
        Tmax=2*Tmax;
    end
%                  finite  bandwidth & slew-rate                   %
%                       error calculation                          %
   deltaV=abs(threshold_id-threshold(i-1));
   slope=deltaV/tau;
   if slope > sr
        tslew=(deltaV/sr) - tau;
            if tslew >= Tmax              % only slewing
                error = deltaV - sr*Tmax;
            else
                texp = Tmax - tslew;
                error = (deltaV-sr*tslew)*exp(-texp/tau);
            end
   else
                % only exponential settling
    texp = Tmax;
    error = deltaV*exp(-texp/tau);
   end
   threshold(i) = threshold_id - sign(threshold_id-threshold(i-1))*error;
%      successive approximation       %
%        conversion algorythm         %
    if (in-threshold(i)) > 0
        threshold_id=threshold_id+1/2^i*v;
        bit=1;
    else
        threshold_id=threshold_id-1/2^i*v;
        bit=0;
    end
Tmax=1/(f_s*nbit);
counter=(counter+bit*2^(nbit-i+1));
thresholds(i-1)=threshold(i);
end
%             Output             %
counter=counter;
if nargout > 1
thresholds=thresholds;
end
那个数字的影响是因为给的转换时间足够长,所以能达到更好效果吗?更细致的原因是什么呢?还有,error calculation那一段明白是在校准比较器的输入什么的,可是不太懂那些式子是怎么来的。请大神不吝赐教啊O(∩_∩)O~
发表于 2016-9-6 12:52:36 | 显示全部楼层
sfdfsdfew
发表于 2017-12-5 09:54:07 | 显示全部楼层
who know it?
GMT+8, 2025-12-28 23:22 , Processed in 0.028704 second(s), 6 queries , Gzip On, Redis On.
