查看: 1406|回复: 0
[招聘] Cadence SH 招聘Principal/Senior Product Engineer
发表于 2015-8-17 14:12:55 | 显示全部楼层 |阅读模式
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your updateCV to job_china@cadence.com
Title: SeniorCustomer Engagement Engineer
PositionDescription:
The primary responsibility is designing,developing, troubleshooting and debugging software programs on Unix/Linuxplatforms.
Will be involved in developing software toolsfor advanced chip design platforms.
The responsibilities also include engaging withcustomers in understanding their ASIC design requirements for nano-technologyprocess nodes and assisting them in adopting Cadence design platform andhelping them in performing successful tape outs of their System-on-chip designsusing the same.
The job will also involves presenting anddemonstrating relevant Cadence technologies and carrying out productevaluations, workshops, trainings and competitive replacement campaigns.
PositionRequirements:
The candidates should have strong in-depthP&R design experience in COT or ASIC area.
Experience and ability to get solutions inFloor plan, Power Planning/Analysis, CTS, timing optimization/analysis, signalintegrity and DFM issues (DRC & Antenna) is a MUST. Strong interest and understandingof design methodologies are required.
Need to have good knowledge on VDSM (40nm andbelow) processes issues.
Good verbal and written presentation are must.
Hands-on Cadence Encounter experience is a bigplus.
Minimum master degrees in EE or CS.
1. Senior Product Engineer-EDI
1. Design and develop cutting edge technologiesof Encounter Digital Implementation (EDI) System, to address future andimmediate customer requirements.
2. Collaborate with R&D and production validationteam to deliver high quality software release
3. Provide techincal support and trainings forCadence AP business
4. Communicate with global cross-function teamto create technical solutions and involve in customer engagement
1. CS/EE MS with IC physical design experience.
2. Be familiar with IC back-end design flow,including place, route, clock tree synthesis and timing optimization.
3. Strong analysis/debug capability fortechnical issues.
4. Good team spirit and be able to work underpressure.
5. Good communication skill in English
2. Principal ProductEngineer (数字后端产品工程)
1.Work in shanghai Engagement PE team, mainlyfocus on TSMC-related project.
20nm and 16nm FinFET flow establishment, from synthesis to final SI timingclosure
2.Work closely with other team members for technique communication andprojects.
3.Can take lead role in project plan and action.
4.Co-work closely with R&D team to find thedebug the software problem in a IC backend way as early as possible.
1. Master with 7-8 years working experience orBachelor with about 10years experience.
IC design background, especially in the back-endflow. Low Power related working experience will be a strong plus.
2. Syntheis, Backend experience, LVS, DRC, CLPknowledge and tape-out experience.
Unix System knowledge, vi/TCL/TK/CSH will beplus.
3. Strong scripting capability, includingshell/tcl/perl.
4. Good communication in English and Chinese,good confidence and good self-motivation.
5. Good team spirit, well-aligned with the"One Cadence, One Team."
3. Principal ProductEngineer -SSV
Position Description:
1. Work in shanghai Silicon Signoff andVerification (SSV) electrical PE team, mainly focus on Virtuoso Power System(VPS) and Voltus Power System (Voltus).
2. Support key customer engagements and localAEs to help on the business increasement.
3. Working as a domain expert to wellcommunicate with customers for their valuable feedbacks
4. Co-work closely with R&D team to enhacethe tool based on customers' real demandings
Position Requirements:
1.Master with 7-8 years working experience or Bachelor with about 10 yearsexperience.
    ICdesign background, especially in Cadence Virtuoso platform. Cadence Encounterplatform experience will be a plus
2. One or both of electrical analysisexperience on power and is necessary
3. Working experience with foundry and processtech files, spice models are desired
4. Product Engineering and customer supportingexperience is desired.
5. Good communication in English and Chinese,good confidence and good self-motivation.
6. Good team spirit, well-aligned with the"One Cadence, One Team."
GMT+8, 2025-12-28 14:18 , Processed in 0.011939 second(s), 3 queries , Gzip On, Redis On.
