查看: 10287|回复: 4
[原创] VCS软件报错,请求帮忙
发表于 2015-7-30 16:34:39 | 显示全部楼层 |阅读模式
vcs -f design.f -f tb.f \
        -sverilog \
        +v2k -Mupdate \
        -fsdb_old \
        +nospecify \
        +notimingcheck \
        +define+NONE \
        -timescale=1ns/1ps \
    -Mdir=./report/simv_case0/csrc \
        -o ./report/simv_case0/simv_case0 \
        -l ./report/simv_case0/compile.log
mkdir: cannot create directory `/tmp/vcs_20150730083129_27416': Read-only file system
/eda/synopsys/VCS/bin//vcs: line 18010: /tmp/vcs_20150730083129_27416/.vcsmx_rebuild: No such file or directory
/eda/synopsys/VCS/bin//vcs: line 18011: /tmp/vcs_20150730083129_27416/elaboptfile_27416: No such file or directory
/eda/synopsys/VCS/bin//vcs: line 1742: /tmp/vcs_20150730083129_27416/time27416:No such file or directory
/usr/bin/tail: cannot open `/tmp/vcs_20150730083129_27416/time27416' for reading: No such file or directory
dc: stack empty
dc: stack empty
                         Chronologic VCS (TM)
            Version H-2013.06 -- Thu Jul 30 16:31:29 2015
               Copyright (c) 1991-2013 by Synopsys Inc.
                         ALL RIGHTS RESERVED
An unexpected termination has occurred in /eda/synopsys/VCS/linux/bin/vcs1
During Error message function Code:="TFIPC"
Module NOR2XB_X2M_A9TR_W3 declared at ../lib/sc9_55hv_base_rvt_w3.v, 135989
During Core design resolution module instance A_u1_oled_sat_m_l at ../netlist/ol
edstar_top.mapped.v, 3259
During Design resolution
During parsing for two step flow
Command line: /eda/synopsys/VCS/linux/bin/vcs1 -Mdir=./report/simv_case0/csrc -M
cc=gcc -Mcplusplus=g++ -Masflags=--32 "-Mcfl= -pipe -m32 -O -I/eda/synopsys/VCS/                include " "-Mldflags= -melf_i386 -m32 " -Mout=./report/simv_case0/simv_case0 -Ma                msrun= -Mvcsaceobjs= "-Mobjects= /eda/synopsys/VCS/linux/lib/libvirsim.so /eda/s                ynopsys/VCS/linux/lib/librterrorinf.so /eda/synopsys/VCS/linux/lib/libsnpsmalloc                .so " -Msaverestoreobj=/eda/synopsys/VCS/linux/lib/vcs_save_restore_new.o -Mcrt0                = -Mcrtn= -Mcsrc= -Mupdate -Mdir=./report/simv_case0/csrc "-Msyslibs=/eda/verdi/                share/PLI/snps_unified/LINUX/pli.a /eda/synopsys/VCS/linux/lib/ctype-stubs_32.a                 -ldl -lm " +v2k -P /eda/verdi/share/PLI/snps_unified/LINUX/novas.tab +cli+4 -fsd                b_old +nospecify +notimingcheck +define+NONE -timescale=1ns/1ps -o ./report/simv                _case0/simv_case0 -l ./report/simv_case0/compile.log +cli+3 +vcsd +itf+/eda/syno                psys/VCS/linux/lib/vcsd.tab +vpi -debug=3 +memcbk -sverilog +vpi -gen_obj -f des                ign.f -f tb.f
--- Stack trace follows:
fail to create: /tmp/vcs_20150730083129_27416/.stack_annotator_gdb_output_file_h                kl4wv
/eda/synopsys/VCS/bin//vcs: line 1742: /tmp/vcs_20150730083129_27416/time27416:                 No such file or directory
/usr/bin/tail: cannot open `/tmp/vcs_20150730083129_27416/time27416' for reading                : No such file or directory
dc: stack empty
dc: stack empty
make: *** [comp] Error 1
发表于 2015-7-31 09:48:14 | 显示全部楼层
你的命令也太多了
 楼主| 发表于 2015-7-31 10:44:48 | 显示全部楼层
回复 2# alienwarexie
   呵呵,是的。问题的根源原来不是VCS,而是linux 系统出问题了,我重启了系统,报了fatal error。问题更大了
Mount: could not find filesystem '/dev/root'
setuproot: moving /dev failed: No such file or directory
setuproot: error mouting /proc: No such file or directory
setuproot: error mouting /sys: No such file or directory
switchroot: mount failed: No such file or directory
Kernel panic - not syncing: Attempted to kill init!
发表于 2020-7-23 11:03:53 | 显示全部楼层
楼主问题 解决了吗?
发表于 2020-7-26 13:46:59 | 显示全部楼层
如果是服务器是不是服务器掉线了,重启一下
GMT+8, 2025-12-23 09:42 , Processed in 0.186628 second(s), 7 queries , Gzip On, Redis On.
