查看: 5770|回复: 1
[求助] 怎么解决formality验证中BBPin unmatched
发表于 2015-7-14 14:50:55 | 显示全部楼层 |阅读模式
怎么解决formality验证中BBPin unmatched问题?我设置了:
set hdlin_ignore_full_case true
set hdlin_ignore_parallel_case false
set hdlin_warn_on_mismatch_message "FMR_ELAB-147"
set hdlin_error_on_mismatch_message true
set hdlin_unresolved_modules black_box
set hdlin_enable_hier_naming true
set verification_set_undriven_signals X
set verification_constant_prop_mode auto
谢谢!
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997845/F/X_LUT4/ADR0\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997845/F/X_LUT4/ADR1\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997845/F/X_LUT4/ADR2\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997845/F/X_LUT4/ADR3\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997945/F/X_LUT4/ADR0\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997945/F/X_LUT4/ADR1\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997945/F/X_LUT4/ADR2\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng2997945/F/X_LUT4/ADR3\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3070/G/X_LUT4/ADR0\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3070/G/X_LUT4/ADR1\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3070/G/X_LUT4/ADR2\*unread\*/IN
  Ref  BBPin      r:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3070/G/X_LUT4/ADR3\*unread\*/IN
  Impl BBPin      i:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3059/F/X_LUT4/ADR0\*unread\*/IN
  Impl BBPin      i:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3059/F/X_LUT4/ADR1\*unread\*/IN
  Impl BBPin      i:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3059/F/X_LUT4/ADR2\*unread\*/IN
  Impl BBPin      i:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3059/F/X_LUT4/ADR3\*unread\*/IN
  Impl BBPin      i:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3060/F/X_LUT4/ADR0\*unread\*/IN
  Impl BBPin      i:/WORK/aquarius_s38417_mapped/S38417_MAPPED/ng3060/F/X_LUT4/ADR1\*unread\*/IN
发表于 2015-11-26 09:31:48 | 显示全部楼层
回复 1# yanpeace
    解决了吗? 我也遇到了这个问题?
GMT+8, 2025-12-14 23:17 , Processed in 0.013188 second(s), 3 queries , Gzip On, Redis On.
