查看: 19005|回复: 17
大虾,本小虾米安装cadence Installscape 出现的问题,运行iscape.sh时跳出的错误
发表于 2015-7-11 22:39:27 | 显示全部楼层 |阅读模式
运行iscape.sh时窗口没有打开,跳出了以下信息,求帮助
电脑系统的64位win7. 用Vmware装的centos32位的虚拟机系统
[root@localhost bin]# sh iscape.sh
Initializing InstallScape using JVM at /opt/cadence/installscape/iscape.04.23-s010/runtime/LNX86/bin/java. This might take some time...
Error occurred during initialization of VM
java/lang/ClassNotFoundException: error in opening JAR file /opt/cadence/installscape/iscape.04.23-s010/runtime/LNX86/lib/rt.jar
Failed with InstallScape JVM.
Now loading System JVM...
iscape.sh: line 219: java: command not found
Error:
which: no java in (/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
Could not use JVM packaged with Installcape. The Java in your path did not work or could not find Java in your path.  Ensure that Java 1.6 or later is in your PATH environment variable and restart InstallScape.
 楼主| 发表于 2015-7-12 09:46:35 | 显示全部楼层
自己顶。。。。。
 楼主| 发表于 2015-7-12 10:17:03 | 显示全部楼层
自己顶。。。。。
发表于 2015-7-13 10:07:44 | 显示全部楼层
你的centos版本?
发表于 2015-7-15 09:45:36 | 显示全部楼层
yum install java*
回复 支持 2 反对 0
发表于 2015-8-24 17:42:39 | 显示全部楼层
同问同问
发表于 2015-9-26 08:15:19 | 显示全部楼层
怎么解决的?
发表于 2018-8-31 21:41:18 | 显示全部楼层
好气,我也遇到一样的了,我正在尝试安装java的开发环境试试,安装jdk
发表于 2018-9-1 14:19:53 | 显示全部楼层
必须赞,感谢分享
发表于 2018-9-1 14:21:36 | 显示全部楼层
回复 1# xy131368
   必须赞,感谢分享
GMT+8, 2025-12-28 05:49 , Processed in 0.023856 second(s), 6 queries , Gzip On, Redis On.
