楼主: sujay
[资料] Questasim 10.2 64bit LINUX wiht Crack and Detail_Installation guide
发表于 2017-2-11 21:53:04 | 显示全部楼层
Fantasticcccccccccccccccccccccccccccccc
发表于 2017-2-11 21:54:21 | 显示全部楼层
thanks alot
发表于 2017-2-25 23:21:55 | 显示全部楼层
thanks forsharing
发表于 2017-3-3 21:09:05 | 显示全部楼层
How many files all?
发表于 2017-3-13 16:12:35 | 显示全部楼层
没有金币了,哎~
发表于 2017-6-20 14:11:22 | 显示全部楼层
请问和0in you 区别吗
发表于 2017-7-9 09:45:24 | 显示全部楼层
i guess i'll have to thank you many time
发表于 2017-7-17 14:30:49 | 显示全部楼层
非常感谢~
报错如下会是因为什么,因为是别人装的,也不知道之前装到哪一步了?
abc@abc-virtual-machine:/opt/questasim$ lmutil lmdiag -c /opt/questasim/mentor.dat
lmutil - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
FLEXnet diagnostics on Mon 7/17/2017 13:07
License file: /opt/questasim/mentor.dat
"mgc_s" v2020.00, vendor: mgcld
  License server: abc-virtual-machine
  floating license  starts: 17-jul-2017,   expires: 1-jan-2021
  TS_OK: Checkout permitted when client is using terminal client
This license cannot be checked out because:
Cannot connect to license server
        ... I will try to determine what the problem is...
"telnet" port (23) on node abc-virtual-machine does not respond
->if abc-virtual-machine is a Unix system, it's probably down
发表于 2017-8-13 13:47:32 | 显示全部楼层
How do I recharge the points?  I got the first 15 RAR files, I really want to get the rest.
发表于 2017-8-13 13:48:43 | 显示全部楼层
This is for Linux, not Windows right?
GMT+8, 2025-12-18 10:35 , Processed in 0.019509 second(s), 5 queries , Gzip On, Redis On.
