查看: 8597|回复: 19
[求助] 小白首次搭建环境
发表于 2015-7-3 19:40:16 | 显示全部楼层 |阅读模式
各位大神前辈好,我是FPGA的小白,周一的时候,师兄给我一系列资料还有软件,让我搭好环境并且把程序装到板子里,可是到现在,我还没有成功,请教各位能教教我大环境么?软件:cygwin
        xilinx ISE
        xilinx vivado
        modelsim
        grtools
资料:grlib-gpl-1.4.1-b4156.tar.gz
板子:xilinx virtex-7
希望能有好人教教我。。。
 楼主| 发表于 2015-7-3 19:54:35 | 显示全部楼层
求教求教。。。希望好心人帮忙
 楼主| 发表于 2015-7-6 09:06:53 | 显示全部楼层
回复 2# johnakeke
   帖子可别沉啊,很着急啊,真心请能帮忙的人帮我一把吧。。。
发表于 2015-7-6 09:41:32 | 显示全部楼层
你用的ISE还是VIVADO?
 楼主| 发表于 2015-7-14 15:02:56 | 显示全部楼层
回复 4# 菜鸟要飞
   我用的是ISE,但是师兄跟我说让我安装cygwin,然后用一系列命令来执行调用各种工具
发表于 2015-7-14 16:57:56 | 显示全部楼层
回复 5# johnakeke
   cygwin 不懂
发表于 2015-7-14 17:19:25 | 显示全部楼层
我也是刚学习ISE,正在摸索阶段
发表于 2015-7-15 11:28:22 | 显示全部楼层
cygwin就是在windows下装的一个linux环境,方便在win下调试linux的软件,你可以把它当成一个虚拟机,但又不完全是
 楼主| 发表于 2015-7-15 17:41:50 | 显示全部楼层
回复 7# qkj5566
   握手握手,同是小白
 楼主| 发表于 2015-7-16 10:31:40 | 显示全部楼层
回复 6# 菜鸟要飞
   This leon3 design is tailored to the Xilinx Virtex-7 VC707 board
http://www.xilinx.com/vc707
Note: This design requires that the GRLIB_SIMULATOR variable is
correctly set. Please refer to the documentation in doc/grlib.pdf for
additional information.
Note: The Vivado flow and parts of this design are still
experimental. Currently the design configuration should be left as-is.
Note: You must have Vivado 2014.4.1 in your path for the make targets to work.
The XILINX_VIVADO variable must be exported for the mig_7series target
to work correctly: export XILINX_VIVADO
Simulation and synthesis
The design uses the Xilinx MIG memory interface with an AHB-2.0
interface and Xilinx SGMII PHY Interface. The MIG or the SGMII PHY
source code cannot be distributed due to the prohibitive Xilinx
license, so the MIG and/or the SGMII must be re-generated with
Vivado before simulation and synthesis can be done.
Xilinx MIG and SGMII interface will automatically be generated when
Vivado is launched
To simulate using XSIM and run systest.c on the Leon design using the memory
controller from Xilinx use the make targets:
  make soft
  make vivado-launch
To simulate using Modelsim/Aldec and run systest.c on the Leon design using
the memory controller from Xilinx use the make targets:
  make map_xilinx_7series_lib
  make sim
  make mig_7series
  make sgmii_7series
  make sim-launch
To simulate using the Aldec Riviera WS flow use the following make targets:
  make riviera_ws               # creates riviera workspace
  make map_xilinx_7series_lib   # compiles and maps xilinx sim libs
  make mig_7series              # generates MIG IP and adds to riviera project
  make sgmii_7series            # same for SGMII adapter
  make riviera                  # compile full project
  make riviera-launch           # launch simulation
To synthesize the design, do
  make vivado
and then use iMPACT programming tool:
  make ise-prog-fpga
to program the FPGA.
After successfully programmed the FPGA using the target 'ise-prog-fpga' user might
have to press the 'CPU RESET' button in order to successfully complete the calibration
process in the MIG. Led 1 and led 2 should be constant green if the Calibration
process has been successful.
If user tries to connect to the board and the MIG has not been calibrated successfully
'grmon' will output:
$ grmon -xilusb -u -nb
  GRMON2 LEON debug monitor v2.0.43-2-g95d293c internal version
  Copyright (C) 2013 Aeroflex Gaisler - All rights reserved.
  For latest updates, go to http://www.gaisler.com/
  Comments or bug-reports to support@gaisler.com
Parsing -xilusb
Parsing -u
Parsing -nb
Commands missing help:
datacache
Xilusb: Cable type/rev : 0x3
JTAG chain (1):
xc7vx485t
AMBA plug&play not found!
Failed to initialize target!
Exiting GRMON
The MIG and SGMII IP can be disabled either by deselecting the memory controller
and Gaisler Ethernet interface in 'xconfig' or manually editing the config.vhd file.
When no MIG and no SGMII block is present in the system normal GRLIB flow can be
used and no extra compile steps are needed. Also when when no MIG is present it
is possible to control and set the system frequency via xconfig.
Note that the system frequency can be modified via Vivado when the MIG is present
by modifying within specified limits for the MIG IP.
Compiling and launching modelsim when no memory controller and no ethernet interface
is present using Modelsim/Aldec simulator:
  make vsim
  make soft
  make vsim-launch
Simulation options
All options are set either by editing the testbench or specify/modify the generic
default value when launching the simulator. For Modelsim use the option "-g" i.e.
to enable processor disassembly to console launch modelsim with the option: "-gdisas=1"
USE_MIG_INTERFACE_MODEL - Use MIG simulation model for faster simulation run time
(Option can now be controlled via 'make xconfig')
disas - Enable processor disassembly to console
DEBUG - Enable extra debug information when using Micron DDR3 models
Design specifics
* Synthesis should be done using Vivado 2014.4.1 or newer
* The DDR3 controller is implemented with Xilinx MIG 7-Series 2.0 and
  runs of the 200 MHz clock. The DDR3 memory runs at 400 MHz
  (DDR3-800). grmon-2.0.30-74 or later is needed to detect the
   DDR3 memory.
* The AHB clock is generated by the MMCM module in the DDR3
  controller, and can be controlled via Vivado. When the
  MIG DDR3 controller isn't present the AHB clock is generated
  from CLKGEN, and can be controlled via xconfig
* System reset is mapped to the CPU RESET button
* DSU break is mapped to GPIO east button
* LED 0 indicates processor in debug mode
* LED 1 indicates processor in error mode, execution halted
* LED 2 indicates DDR3 PHY initialization done (Only valid when MIG is present)
* LED 3 indicates internal PLL has locked (Only valid when MIG isn't present)
* 16-bit flash prom can be read at address 0. It can be programmed
  with GRMON version 2.0.30-74 or later.
* The application UART1 is connected to the USB/RS232 connector if
  switch 5, located on the DIP Switch SW2 of the board, is set to OFF.
* The AHB UART can be enabled by setting switch 5 to ON.
  Since the board is equipped with one USB/RS232 connector, APB UART1 and
  AHB UART cannot be used at the same time.
* The JTAG DSU interface is enabled and accesible via the JTAG port.
  Start grmon with -xilusb to connect.
* Output from GRMON is:
grmon -xilusb
  GRMON2 LEON debug monitor v2.0.30-149-ga91ee12 internal version
  Copyright (C) 2012 Aeroflex Gaisler - All rights reserved.
Parsing -xilusb
JTAG chain (1): xc7vx485t
debug
  GRLIB build version: 4118
  Detected frequency:  100 MHz
  Component                            Vendor
  LEON3 SPARC V8 Processor             Aeroflex Gaisler
  AHB Debug UART                       Aeroflex Gaisler
  JTAG Debug Link                      Aeroflex Gaisler
  LEON2 Memory Controller              European Space Agency
  AHB/APB Bridge                       Aeroflex Gaisler
  LEON3 Debug Support Unit             Aeroflex Gaisler
  Single-port AHB SRAM module          Aeroflex Gaisler
  Unknown device                       Aeroflex Gaisler
  Generic UART                         Aeroflex Gaisler
  Multi-processor Interrupt Ctrl.      Aeroflex Gaisler
  Modular Timer Unit                   Aeroflex Gaisler
  AMBA Wrapper for OC I2C-master       Aeroflex Gaisler
  General Purpose I/O port             Aeroflex Gaisler
  Use command 'info sys' to print a detailed report of attached cores
grmon2> info sys
  cpu0      Aeroflex Gaisler  LEON3 SPARC V8 Processor
            AHB Master 0
  ahbuart0  Aeroflex Gaisler  AHB Debug UART
            AHB Master 1
            APB: 80000700 - 80000800
            Baudrate 115200, AHB frequency 100.00 MHz
  ahbjtag0  Aeroflex Gaisler  JTAG Debug Link
            AHB Master 2
  mctrl0    European Space Agency  LEON2 Memory Controller
            AHB: 00000000 - 20000000
            APB: 80000000 - 80000100
            16-bit prom @ 0x00000000
  apbmst0   Aeroflex Gaisler  AHB/APB Bridge
            AHB: 80000000 - 80100000
  dsu0      Aeroflex Gaisler  LEON3 Debug Support Unit
            AHB: 90000000 - A0000000
            AHB trace: 256 lines, 32-bit bus
            CPU0:  win 8, hwbp 2, itrace 256, V8 mul/div, srmmu, lddel 1
                   stack pointer 0x20000ff0
                   icache 4 * 8 kB, 32 B/line dir
                   dcache 4 * 8 kB, 32 B/line dir
  ahbram0   Aeroflex Gaisler  Single-port AHB SRAM module
            AHB: 20000000 - 20100000
            32-bit static ram: 4 kB @ 0x20000000
  adev7     Aeroflex Gaisler  Unknown device
            AHB: 40000000 - 48000000
            APB: 80000400 - 80000500
  ahbram1   Aeroflex Gaisler  Single-port AHB SRAM module
            AHB: A0000000 - A0100000
            32-bit static ram: 4 kB @ 0xa0000000
  uart0     Aeroflex Gaisler  Generic UART
            APB: 80000100 - 80000200
            IRQ: 2
            Baudrate 38343
  irqmp0    Aeroflex Gaisler  Multi-processor Interrupt Ctrl.
            APB: 80000200 - 80000300
  gptimer0  Aeroflex Gaisler  Modular Timer Unit
            APB: 80000300 - 80000400
            IRQ: 8
            8-bit scalar, 2 * 32-bit timers, divisor 100
  i2cmst0   Aeroflex Gaisler  AMBA Wrapper for OC I2C-master
            APB: 80000800 - 80000900
            IRQ: 11
  gpio0     Aeroflex Gaisler  General Purpose I/O port
            APB: 80000A00 - 80000B00
grmon2> load systest.exe
  40000000 .text                    112.2kB / 112.2kB   [===============>] 100%
  40020000 .data                    163.1kB / 163.1kB   [===============>] 100%
  Total size: 275.28kB (1.19Mbit/s)
  Entry point 0x40000000
  Image /home/ringhage/grlib_git/designs/leon3-xilinx-vc707/systest.exe loaded
grmon2> verify systest.exe
  Total size: 275.28kB (85.23kbit/s)
  Image of /home/ringhage/grlib_git/designs/leon3-xilinx-vc707/systest.exe verified without errors
grmon2>
* grmon output using Ethernet
grmon -eth -ip 192.168.0.51 -u -nb
  GRMON2 LEON debug monitor v2.0.33-88-g17c6483 internal version
Parsing -eth
Parsing -ip 192.168.0.51
Parsing -u
Parsing -nb
debug
datacache
Ethernet startup...
  GRLIB build version: 4129
  Component                            Vendor
  GR Ethernet MAC                      Aeroflex Gaisler
  USB Debug Communication Link         Aeroflex Gaisler
  Xilinx MIG DDR3 Controller           Aeroflex Gaisler
grmon2> info sys
            AHB Master 0
            AHB Master 1
            AHB Master 2
  greth0    Aeroflex Gaisler  GR Ethernet MAC
            AHB Master 3
            APB: 80000E00 - 80000F00
            IRQ: 12
            1000 Mbit capable
            edcl ip 192.168.0.51, buffer 2 kbyte
  adev4     Aeroflex Gaisler  USB Debug Communication Link
            AHB Master 4
                   stack pointer 0x7ffffff0
                   icache 4 * 4 kB, 32 B/line dir
                   dcache 4 * 4 kB, 32 B/line dir
  mig0      Aeroflex Gaisler  Xilinx MIG DDR3 Controller
            AHB: 40000000 - 80000000
            SDRAM: 1024 Mbyte
            IRQ: 2
            Baudrate 38343
            IRQ: 8
            APB: 80000900 - 80000A00
            IRQ: 11
  adev16    Aeroflex Gaisler  Unknown device
            APB: 80000B00 - 80000C00
grmon2> load /usr/local32/apps/bench/leon3/dhry.leon3
  40000000 .text                     54.7kB /  54.7kB   [===============>] 100%
  4000DAF0 .data                      2.7kB /   2.7kB   [===============>] 100%
  Total size: 57.44kB (17.43Mbit/s)
  Image /usr/local32/apps/bench/leon3/dhry.leon3 loaded
grmon2> run
Execution starts, 1000000 runs through Dhrystone
Total execution time:                          4.6 s
Microseconds for one run through Dhrystone:    4.6
Dhrystones per Second:                      217085.5
Dhrystones MIPS      :                       123.6
  Program exited normally.
grmon2> exit
* grmon output using digilent
grmon -digilent -u
Parsing -digilent
Parsing -u
debug
datacache
  Component                            Vendor
grmon2> info sys
            AHB Master 0
            AHB Master 1
            AHB Master 2
            AHB Master 3
            IRQ: 12
            1000 Mbit capable
            AHB Master 4
            SDRAM: 1024 Mbyte
            IRQ: 2
            Baudrate 38343
            IRQ: 8
            IRQ: 11
grmon2>
* grmon output using USB debug link
sudo grmon -usb -nb -u
Parsing -usb
Parsing -nb
Parsing -u
debug
datacache
  Component                            Vendor
  Total size: 57.44kB (24.77Mbit/s)
grmon2> verify  /usr/local32/apps/bench/leon3/dhry.leon3
  Total size: 57.44kB (13.84Mbit/s)
  Image of /usr/local32/apps/bench/leon3/dhry.leon3 verified without errors
grmon2> run
Dhrystones per Second:                      216215.1
Dhrystones MIPS      :                       123.1
grmon2>
GMT+8, 2025-12-14 13:51 , Processed in 0.027853 second(s), 6 queries , Gzip On, Redis On.
