发表于 2009-3-20 02:19:59
显示全部楼层
1. If you care about absolute value, trimming is a must. No one can do 1% accuracy without trimming in the world.
2. Many many ADC do NOT require absolute accuarcy. That is to say if you get +/-3% without trimming, it will be acceptable.
However, for temp. coef., some applications require as flat as possible for Vref vs temp. In that case, you need compensate temp. effect only. Let alone the variations for Vref vs P(as long as +/-3%) |
