楼主: czn
book_Phase Locked Loop Synthesizer Simulation
 楼主| 发表于 2007-4-28 22:22:50 | 显示全部楼层
http://www.vonl.com/chips/phaslock.htm
Phase-Locked Loop Synthesizer Simulation
by Giovanni Bianchi
Phase-Locked Loop Synthesizer Simulation describes how to calculate PLL performances by using standard mathematical or circuit analysis programs. Theoretical descriptions are limited to the minimum needed to explain how to perform calculations. Although presented methods of analysis can be implemented with many commercial programs, their description always refers to Mathcad and SIMetrix. Contents:
  • Phase-Locked Loop Basics
    • Introduction
    • PLL Working Principles
    • Laplace and Fourier Transforms
    • Definitions
    • Basic properties
    • Transforms of some important functions
    • PLL Transfer Functions
    • PLL stability analysis
    • PLL Order and PLL Type
    • First-Order PLL
    • Second-Order PLL
    • References
  • Loop Components
    • Introduction
    • Phase Detector
    • Multiplier as phase detector
    • Phase frequency detector
    • Loop Filter
    • Reference spur filtering
    • Loop filters for voltage output phase detectors
    • Loop filters for charge pump
    • Loop filter scaling
    • VCO
    • Principle of working
    • VCO analysis
    • Phase Noise
    • Pulling and pushing
    • Reference Sources
    • Frequency Dividers
    • Frequency divider phase noise
    • References
  • Fractional-N Frequency Divider
    • Introduction
    • Single-Accumulator Fractional Divider
    • Multiple-Accumulator Fractional Dividers
    • Z transform
    • First-order _-_ modulator
    • Higher-order _-_ converters
    • Multiple-accumulator fractional-N phase noise
    • References
  • Synthesizer Performance Simulation
    • Introduction
    • Simulation Techniques
    • Phase Noise
    • Definitions
    • Phase noise of PLL synthesizer
    • Modulation of the PLL
    • Modulation of the reference oscillator only
    • Modulation of the VCO only
    • Dual-point modulation
    • Settling Time
    • Lock-in
    • Pull-in
    • Final Note on Circuit-Based Simulation
    • References
  • Miscellaneous
    • Introduction
    • PLL Performance Verification
    • Measurement of PLL frequency response magnitude
    • Sampling Phase Detector
    • Multiple-Loop PLL
    • Phase noise of multiple-loop PLL
    • Transients in multiple-loop PLL
    • Variations on double-loop architecture
    • Direct Digital Synthesizer
    • Principle of DDS operation
    • Effects of nonideal components on DDS performance
    • Enhancements of DDS architecture
    • References
Index
发表于 2007-4-30 00:46:32 | 显示全部楼层
xiexie LZ.
for your information, this is a scan version.
发表于 2007-4-30 02:20:56 | 显示全部楼层
ding
发表于 2007-4-30 22:53:03 | 显示全部楼层
thanks for sharing
发表于 2007-5-2 17:40:44 | 显示全部楼层
好书好书啊,收藏了
发表于 2007-5-2 20:41:28 | 显示全部楼层
it 's a good data
but i have not enough money
thanks of your sharing!!
头像被屏蔽
发表于 2007-5-4 19:36:23 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2007-5-13 12:03:38 | 显示全部楼层
先顶在下 a
发表于 2007-5-13 17:17:31 | 显示全部楼层
dingdingding
发表于 2007-5-13 17:20:37 | 显示全部楼层
太贵了!!!!!!!!!!
GMT+8, 2025-12-13 08:55 , Processed in 0.019711 second(s), 3 queries , Gzip On, Redis On.
