查看: 5378|回复: 0
Error:it does not hold its value outside the clock edge
发表于 2007-4-28 14:03:18 | 显示全部楼层 |阅读模式
Rd_FIFO_Clk_Num_Proc:
  process (Reset,Clk16X)
  begin
   if (Reset='1') then
       DOUT_FIFO <= (others => '1');
       After_RD_CLK <= (others => '0');
   -- elsif rising_edge(Clk16X) then
elsif (ADDR_s = A_RBR) and (RDn_cs = '0')then
     After_RD_CLK <=  After_RD_CLK + 1;
   end if;
   DOUT_FIFO <= RXFIFOQ;
    else
    end if;
  end process Rd_FIFO_Clk_Num_Proc;
把红色部分换成
在综合的时候 就会报错
Error (10001): Verilog HDL or VHDL error at intface.vhd(574): can't infer register for After_RD_CLK[0] because it does not hold its value outside the clock edge
点击报错信息是在紫色的 reset 语句
谁能告诉我怎么会这样呢?
GMT+8, 2025-12-28 23:23 , Processed in 0.014226 second(s), 5 queries , Gzip On, Redis On.
