查看: 42768|回复: 145
protal DXP的封装库
发表于 2007-4-27 13:10:21 | 显示全部楼层 |阅读模式
protal DXP的封装库
[ 本帖最后由 syl0213 于 2007-5-15 08:49 编辑 ]
PCBfootprints.zip
2.49 MB, 下载次数: 4061 , 下载积分: 资产 -2 信元, 下载支出 2 信元
protal DXP的封专库
 楼主| 发表于 2007-4-27 13:33:42 | 显示全部楼层
Axial Lead Diode.PcbLib BGA (0.8mm Pitch, Square).PcbLib BGA (1.27mm Pitch, Square1).PcbLib BGA (1.27mm Pitch, Square2).PcbLib BGA (1.27mm Pitch, Square3).PcbLib BGA (1.27mm Pitch, Square4).PcbLib BGA (1.27mm Pitch, Square5).PcbLib BGA (1.5mm Pitch, Square1).PcbLib BGA (1.5mm Pitch, Square2).PcbLib BGA (1.5mm Pitch, Square3).PcbLib BGA (1.5mm Pitch, Square4).PcbLib BGA (1mm Pitch, Square1).PcbLib BGA (1mm Pitch, Square2).PcbLib BGA (1mm Pitch, Square3).PcbLib BGA (1mm Pitch, Square4).PcbLib BGA (1mm Pitch, Square5).PcbLib BGA (1mm Pitch, Square6).PcbLib BGA (~0.6mm Pitch, Square).PcbLib BGA - Rectangle.PcbLib Bridge Rectifier.PcbLib Bumpered QFP - Centre Index.PcbLib Bumpered QFP - Corner Index.PcbLib CAN - Circle pin arrangement.PcbLib CAN - Rectangle pin arrangement.PcbLib CCGA - Square.PcbLib Capacitor Electrolytic Mount Ring.PcbLib Capacitor Electrolytic Snap-In.PcbLib Capacitor Non-Polar Axial.PcbLib Capacitor Non-Polar Dipped Radial.PcbLib Capacitor Non-Polar Disc.PcbLib Capacitor Non-Polar Radial.PcbLib Capacitor Non-Polar Tubular.PcbLib Capacitor Polar Axial.PcbLib Capacitor Polar Radial Cylinder.PcbLib Capacitor Tantalum Leadless.PcbLib Capacitor Tantalum Radial Bead.PcbLib Capacitor Tantalum Radial Oval.PcbLib Capacitor Tantalum Radial Rectangle.PcbLib Ceramic DFP.PcbLib Ceramic QFP (Square).PcbLib Chip Capacitor - 2 Contacts.PcbLib Chip Diode - 2 Contacts.PcbLib Chip Inductor - 2 Contacts.PcbLib Chip Resistor - 2 Contacts.PcbLib Con 050 DSubminiature.PcbLib Con Audio.PcbLib Con CardEdge.PcbLib Con CompactPCI.PcbLib Con DIN Circular.PcbLib Con Docking Station.PcbLib Con FPC-FFC.PcbLib Con High-Speed PCB.PcbLib Con IEEE1394.PcbLib Con Mains Power.PcbLib Con Mod Jack PCB.PcbLib Con RF Coaxial.PcbLib Con Rect Stag PCB.PcbLib Con USB.PcbLib Crystal Oscillator.PcbLib Cylinder with Flat Index.PcbLib D-PAK.PcbLib DIP - LED Display.PcbLib DIP - Peg Leads.PcbLib DIP, Modified - Trimmed Leads.PcbLib DIP, Shrink - Stub Leads.PcbLib Diamond Base CAN - 2 Leads.PcbLib Diamond Base CAN - 3+ Leads.PcbLib Dual-In-Line Package.PcbLib FQFP (0.3mm Pitch, Square) - Corner Index.PcbLib FQFP (0.4mm Pitch, Square) - Corner Index.PcbLib FQFP (0.5mm Pitch, Square) - Corner Index.PcbLib FQFP - Rectangle.PcbLib Flange Mount with Rectangular Base.PcbLib Horizontal, Flange Mount with Tab.PcbLib Leaded Chip Carrier (Square) - Centre Index.PcbLib Leaded Chip Carrier (Square) - Corner Index.PcbLib Leaded Chip Carrier - Rectangle.PcbLib Leadless Chip Carrier - Rectangle.PcbLib Leadless Chip Carrier - Square.PcbLib Low Profile Module (LPM).PcbLib MELF - Diode.PcbLib MELF - Resistor.PcbLib Miscellaneous Connector PCB.PcbLib Miscellaneous Devices PCB.PcbLib Miscellaneous.PcbLib Pin Grid Array Package (PGA).PcbLib QFP (~0.6mm Pitch, Square) - Centre Index.PcbLib QFP (~0.6mm Pitch, Square) - Corner Index.PcbLib QFP (~0.8mm Pitch, Square) - Corner Index.PcbLib QFP - Rectangle.PcbLib Quad Flat No Lead Square.PcbLib Quad In-Line Package (QUIP).PcbLib Resistor - Axial.PcbLib SOT - 3 Flat Leads.PcbLib SOT 143.PcbLib SOT 223.PcbLib SOT 23 - 5 and 6 Leads.PcbLib SOT 23.PcbLib SOT 343.PcbLib SOT 89.PcbLib Shrink Small Outline (~0.6mm Pitch).PcbLib Single In-Line with Mounting Hole.PcbLib Single In-Line with no Mounting Hole.PcbLib Single-In-Line Package - 5+ Leads.PcbLib Small Outline (+1.27mm Pitch).PcbLib Small Outline (~0.8mm Pitch).PcbLib Small Outline (~1.27mm Pitch) - 22+ Leads.PcbLib Small Outline (~1.27mm Pitch) - 6to20 Leads.PcbLib Small Outline Capacitor - 2 C-Bend Leads.PcbLib Small Outline Diode - 2 C-Bend Leads.PcbLib Small Outline Diode - 2 Flat Leads.PcbLib Small Outline Diode - 2 Gullwing Leads.PcbLib Small Outline Diode - 2 Yoke Leads.PcbLib Small Outline Diode - 2 Z-Bend Leads.PcbLib Small Outline Diode - 3+ Flat Leads.PcbLib Small Outline with C-Bend Leads.PcbLib Small Outline with J Leads.PcbLib TSOP (0.4mm Pitch).PcbLib TSOP (0.5mm Pitch).PcbLib TSOP (~0.6mm Pitch).PcbLib Vertical, Dual-Row, Flange Mount with Tab.PcbLib Vertical, Single-Row, Flange Mount with Tab.PcbLib Zig-Zag-In-Line Package Odd Lead Number.PcbLib Zig-Zag-In-Line Package, Even Lead Number.PcbLib
发表于 2007-5-13 08:54:49 | 显示全部楼层
好东东啊,多谢了!
发表于 2007-5-31 11:59:45 | 显示全部楼层
好东西!!!
发表于 2007-6-2 15:17:32 | 显示全部楼层
bucuo
发表于 2007-6-8 14:59:08 | 显示全部楼层
都不知道该如何感谢了
发表于 2007-6-18 14:58:04 | 显示全部楼层
看看再说。
发表于 2007-7-5 14:18:34 | 显示全部楼层
感谢LZ!
学习,学习,再学习!
发表于 2007-8-16 09:15:21 | 显示全部楼层
这么多呀。
发表于 2007-8-16 17:42:36 | 显示全部楼层
xia bu liao ya .
GMT+8, 2025-9-16 15:00 , Processed in 0.019085 second(s), 7 queries , Gzip On, Redis On.
