查看: 22204|回复: 101
TI公司Understanding Operational Amplifier Specifications(对仿真很有作用)!
发表于 2007-4-25 12:34:17 | 显示全部楼层 |阅读模式
Abstract........................................................................................................................ 7
Product Support on the World Wide Web................................................................... 8
Introduction................................................................................................................... 9
Amplifier Basics ........................................................................................................ 9
Ideal Op Amp Model ............................................................................................... 10
Non-Inverting Amplifier.............................................................................................. 13
Closed Loop Concepts and Simplifications ............................................................. 14
Inverting Amplifier...................................................................................................... 15
Closed Loop Concepts and Simplifications ............................................................. 16
Simplified Op Amp Circuit Diagram .......................................................................... 17
Op Amp Specifications .............................................................................................. 19
Operational Amplifier Glossary ............................................................................... 19
Absolute Maximum Ratings and Recommended Operating Conditions .................. 23
Input Offset Voltage................................................................................................ 24
Input Current........................................................................................................... 25
Input Common Mode Voltage Range...................................................................... 25
Differential Input Voltage Range ............................................................................. 28
Maximum Output Voltage Swing............................................................................. 29
Large Signal Differential Voltage Amplification........................................................ 30
Input Parasitic Elements ......................................................................................... 30
Input Capacitance........................................................................................... 31
Input Resistance............................................................................................. 31
Output Impedance .................................................................................................. 32
Common-Mode Rejection Ratio.............................................................................. 32
Supply Voltage Rejection Ratio............................................................................... 33
Supply Current........................................................................................................ 33
Slew Rate at Unity Gain.......................................................................................... 33
Equivalent Input Noise............................................................................................ 34
Total Harmonic Distortion plus Noise...................................................................... 36
Unity-Gain Bandwidth and Phase Margin ............................................................... 37
Settling Time........................................................................................................... 41
References.................................................................................................................. 42
TI_op_amp.pdf
221.71 KB, 下载次数: 987 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-4-25 12:37:10 | 显示全部楼层
GOOD!
 楼主| 发表于 2007-4-25 23:42:25 | 显示全部楼层
下次争取再发点好资料!
发表于 2007-7-20 15:37:02 | 显示全部楼层
thanks
发表于 2007-7-20 16:31:18 | 显示全部楼层
非常好的资料
谢谢楼主
发表于 2007-7-20 16:45:26 | 显示全部楼层
谢谢
:lol :lol
发表于 2007-8-10 06:32:07 | 显示全部楼层
感謝作者分享.正好要學習OPA
发表于 2007-8-10 09:45:59 | 显示全部楼层
kankanzaishuo
发表于 2007-8-10 21:23:45 | 显示全部楼层
xie xie
发表于 2007-8-11 18:21:28 | 显示全部楼层
真是好东东
GMT+8, 2025-12-24 20:24 , Processed in 0.107273 second(s), 7 queries , Gzip On, Redis On.
