楼主: bu2004
[经典] Edward Lee 的经典数字通信教材
发表于 2008-7-18 11:10:42 | 显示全部楼层
RFM_EXT_R_POSRFM_EXT_R_POSRFM_EXT_R_POSRFM_EXT_R_POSRFM_EXT_R_POSRFM_EXT_R_POSRFM_EXT_R_POSRFM_EXT_R_POS
发表于 2008-7-18 11:11:44 | 显示全部楼层
RF modulator internal voltage regulatorRF modulator internal voltage regulatorRF modulator internal voltage regulatorRF modulator internal voltage regulator
发表于 2008-7-18 11:13:25 | 显示全部楼层
Allows the ring Oscillator to be suppressedAllows the ring Oscillator to be suppressedAllows the ring Oscillator to be suppressedAllows the ring Oscillator to be suppressed
发表于 2008-7-18 11:14:32 | 显示全部楼层
Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)
发表于 2008-7-18 11:15:44 | 显示全部楼层
Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)
发表于 2008-7-18 11:16:59 | 显示全部楼层
Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)
发表于 2008-7-18 11:27:44 | 显示全部楼层
发表于 2008-7-18 11:28:31 | 显示全部楼层
Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)Smart card reset output (selectable open-drain or push-pull)
发表于 2008-7-18 11:33:49 | 显示全部楼层
发表于 2008-12-30 10:50:26 | 显示全部楼层
Digital Communication
是本好书,要了,谢谢楼主!!!!!!!!!!
GMT+8, 2025-11-3 15:23 , Processed in 0.038306 second(s), 3 queries , Gzip On, Redis On.
