查看: 2225|回复: 0
求助:linux内核加载文件系统出错
发表于 2007-4-10 23:23:16 | 显示全部楼层 |阅读模式
Starting kswapd v1.8
pty: 256 Unix98 ptys configured
block: queued sectors max/low 9632kB/3210kB, 64 slots per queue
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
ide-floppy driver 0.97.sv
loop: loaded (max 8 devices)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "" or 02:00
Please append a correct "root=" boot option
Kernel panic: VFS: Unable to mount root fs on 02:00
这是出错提示。大哥们帮帮忙吧。
我用别人的内核加载我的文件系统就可以成功。小弟新手.....
GMT+8, 2025-10-20 01:36 , Processed in 0.019107 second(s), 7 queries , Gzip On, Redis On.
