查看: 1340|回复: 0
[招聘] NO.196-Application Engineer Product Application(Shanghai)
发表于 2015-5-28 14:19:22 | 显示全部楼层 |阅读模式
1. Application Engineer Product Application (7B/8A,PCB硬件背景+实验室经验,3年或以上)
Roles and Responsibilities:
-Product application expertfor sensorproducts
-Global technical lead for selected BST products
-Build up sensor based prototypes including quantitative and qualitative measurement
-product training to FAE and customer
-spec definition, ramp-up, roll-out and phase out activities together with MKT
Key Performance Indicators(optional):
Professional experience in electronics, Semiconductor.Understanding of SW Engineering, communication, independent work style, responsibility, quality of work
Qualification Requirement:
(e.g. Education, Working Experience, Knowledge, Skills, Language, Competence, etc)
-Engineering Degree (BSc. or Master) Electronics, Communications or equivalent experience, desired 2+ years experience.
-Experience in semiconductor components with sensors related
-Experience in hardware electronic design and board level tasks
-Experience in consumer electronics and mobile phone industry
-Experience in board level debugging using embedded SW
-Lab skills including electronic and mechanical testing, soldering
2. Application Engineer Product Application (8A/8B, 加速度传感器,硬件设计+懂嵌入式开发,5-6年经验)
-Product application expertfor sensor and sensor hub products
Professional experience in electronics, Semiconductor and embedded system. Understanding of SW Engineering, communication, independent work style, responsibility, quality of work
-Engineering Degree (BSc. or Master) Electronics, Communications or equivalent experience, desired 4+ years experience.
-Strong experience in semiconductor components such as SoC, sensors
-Strong experience in hardware electronic design and board level tasks
-Experience in consumer electronics and wearable device industry
-Experience in board level debugging with modifying corresponding SW
-Software prototypedeveloping and debugging (embedded software)
3. Application Engineer Product Application (8B/9A, 手机附件产品-手机投影仪,或者,DLP,背投,镭射都可以,英语流利,需要和德国研发团队合作。)
-Product application expertfor sensorand electronic optical products
-Guide the OEM and customers in using the sensors to build up system and how to do the quantitative and qualitative measurement
-Engineering Degree (BSc. or Master) Electronics, Image process or equivalent experience, desired 6+ years experience.
-Strong experience in consumer products such as DLP, Projector and other electronic optical system
-Experience in laser system or projector system architecture
-Experience in image quality testing
-Experience in DLP, Projector device certification, KPI measurement
-Familiar to using MatLAB, Labview is preferred.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“凯轶—KT咨询”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“凯轶—KT咨询”即可添加,欢迎大家关注!
或者直接扫我哦!
GMT+8, 2025-12-28 04:28 , Processed in 0.026411 second(s), 7 queries , Gzip On, Redis On.
