查看: 6743|回复: 12
[求助] 关于gvim的一个功能
发表于 2015-5-11 21:26:59 | 显示全部楼层 |阅读模式
想请教大家一个问题,就是关于怎么设置让gvim的光标能够在一个匹配的begin-end之间进行跳动,有的时候代码层级太多看着犯晕,看不清代码层次。
发表于 2015-5-12 16:27:17 | 显示全部楼层
用% 可跳到最近的{} 块里面
 楼主| 发表于 2015-5-12 22:31:03 | 显示全部楼层
回复 2# icfbicfb
   谢谢,记得好像可以在vimrc里面设置自定义关键字的,比如module-endmodule等,以前看别人弄过,现在找不到了。
发表于 2015-5-13 10:25:43 | 显示全部楼层
   楼上说的是matchit插件:Examples:        Suppose you >                :let b:match_words = '<:>,<tag>:</tag>'<        and hit "%" with the cursor on or before the "<" in "a <tag> is born".        The pattern '<' comes first, so it is preferred over '<tag>', which        also matches.  If the cursor is on the "t", however, then '<tag>' is        preferred, because this matches a bit of text containing the cursor.        If the two groups of patterns were reversed then '<' would never be        preferred.        Suppose you >                :let b:match_words = 'if:end if'<        (Note the space!) and hit "%" with the cursor at the end of "end if".        Then "if" matches, which is probably not what you want, but if the        cursor starts on the "end " then "end if" is chosen.  (You can avoid        this problem by using a more complicated pattern.)
http://ftp.stust.edu.tw/vim/runtime/macros/matchit.txt
发表于 2015-5-13 10:26:25 | 显示全部楼层
回复  icfbicfb
   谢谢,记得好像可以在vimrc里面设置自定义关键字的,比如module-endmodule等,以前 ...
logue 发表于 2015-5-12 22:31
   楼上说的是matchit插件:
发表于 2015-5-13 10:26:58 | 显示全部楼层
回复  icfbicfb
楼上说的是matchit插件
 楼主| 发表于 2015-5-15 20:08:34 | 显示全部楼层
回复 6# sjtusonic
好的,我研究看看,非常感谢!
发表于 2015-7-23 16:07:19 | 显示全部楼层
普通模式用*
发表于 2015-8-1 21:11:55 | 显示全部楼层
谢谢分享~~
发表于 2018-1-19 02:24:04 | 显示全部楼层
學習了
GMT+8, 2025-12-19 12:16 , Processed in 0.022224 second(s), 4 queries , Gzip On, Redis On.
