查看: 3010|回复: 0
[求助] AXI4 Stream中position byte是什么意思?
发表于 2015-5-8 11:38:12 | 显示全部楼层 |阅读模式
如题,在Stream中分为2种数据,一种是postion byte,一种是data byte,data byte容易理解,就是要传输的数据。可是position byte是什么呢?里面包含的是什么内容?用于做什么的?如果能举个小例子就更好了,请教高手解答,不胜感谢。
下面是摘自文档中的部分:
Data byte: A byte of data that contains valid information that is transmitted between the source and destination.
Position byte: A byte that indicates the relative positions of data bytes within the stream. This is a placeholder that does not contain any relevant data values that are transmitted between the source and destination.
GMT+8, 2025-9-17 15:12 , Processed in 0.013858 second(s), 5 queries , Gzip On, Redis On.
