查看: 3679|回复: 4
[求助] 关于仿真电路的搭建
发表于 2015-4-20 21:42:40 | 显示全部楼层 |阅读模式
想请教一下,这个前端的差分电容在cadence里边怎么构造出来啊。。。。。求大神指教。。。。多谢
 楼主| 发表于 2015-4-20 21:50:50 | 显示全部楼层
是在cadence spectre下(Linux)
发表于 2015-4-28 15:16:03 | 显示全部楼层
“C0 + delta C”  “C0 - delta C ” 两者串起来接入输入端既可
 楼主| 发表于 2015-4-29 15:45:49 | 显示全部楼层
回复 3# lmgrd
   谢谢
发表于 2015-4-29 16:14:07 | 显示全部楼层
回复 2# jinpukun
像楼主求教:
   导入verilog生成逻辑控制电路,但是有问题无法生成symbol,小女子不胜感激。
*W,DLNOHV: Unable to find an 'hdl.var' file to load in.
TOOL:
ncvlog
05.50-E115: Started on Apr 29, 2015 at 15:26:03 CST
ncvlog
    -use5x
    -ESCAPEDNAME
    -work __nclib
    -view module
    -logfile ncvlog.log
    -cdslib /tmp/ihdl_cdsliba2756_22756
    -messages
    -nostdout
    -nocopyright
    /home/dianke/ic5141/design/sar_logic.v
file: /home/dianke/ic5141/design/sar_logic.v
assign start   =!en_! & en_reg;
ncvlog:
*E,EXPSMC (/home/dianke/ic5141/design/sar_logic.v,28|20): expecting a semicolon (';') [6.1(IEEE)].
                 begin
ncvlog:
*E,CSISYX (/home/dianke/ic5141/design/sar_logic.v,110|21): case item syntax error [9.5(IEEE)].
                default:
ncvlog:
*E,NOTSTT (/home/dianke/ic5141/design/sar_logic.v,114|22): expecting a statement [9(IEEE)].
               endcase
ncvlog:
*E,NOTSTT (/home/dianke/ic5141/design/sar_logic.v,119|21): expecting a statement [9(IEEE)].
module __nclib.sar_logic:module
errors: 4, warnings: 0
Total errors/warnings found outside modules and primitives:
errors: 0, warnings: 1
TOOL:
ncvlog
05.50-E115: Exiting on Apr 29, 2015 at 15:26:03 CST  (total: 00:00:00)
GMT+8, 2025-12-14 21:03 , Processed in 0.023744 second(s), 6 queries , Gzip On, Redis On.
