查看: 10263|回复: 10
[求助] How to solve "Dumping VCS Annotated Stack" error???
发表于 2015-4-17 17:56:43 | 显示全部楼层 |阅读模式
There is a simple verilog file:
module test;
  initial begin
     $display("\nHello, World!\n");
  end
endmodule
when I run the vcs :   vcs -full64  +v2k -sverilog test.v -o simv -R
But after compilation, There is a stack error:
Dumping VCS Annotated Stack:
#0  0x00000031718ac8fd in waitpid () from /lib64/libc.so.6
#1  0x000000317183e909 in do_system () from /lib64/libc.so.6
#2  0x000000317183ec40 in system () from /lib64/libc.so.6
#3  0x00007f4541f2a515 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e639d2928478c79b3f673f99203bcf8be64600612100082236bffb2007f1e0ef9 () from /home/Tools/vcs/amd64/lib/liberrorinf.so
#4  0x00007f4541f2bc52 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313efba706aab251478fa49e66610e453774633a6c152e7ef778f2202cda681f3d4e () from /home/Tools/vcs/amd64/lib/liberrorinf.so
#5  0x00007f4541f23b0d in SNPSle_d35ca1ff70d465c2b9b1a72eee90a506fdd009d3de3db1de () from /home/Tools/vcs/amd64/lib/liberrorinf.so
No context available
Note: Execution of simv exited with code 1
CPU time: .152 seconds to compile + .216 seconds to elab + .216 seconds to link + .580 seconds in simulation
The OS is RHEL 6.5, VCS is v201412sp1
Some nice guys, could you tell me how can I solve this problem?
发表于 2016-1-8 16:18:32 | 显示全部楼层
同问。。
发表于 2016-3-15 15:44:15 | 显示全部楼层
回复 1# 飞扬紫百合
    解决了, 是license问题
发表于 2016-4-16 09:03:23 | 显示全部楼层
回复 3# tinytera
   你是怎么解决的啊?
发表于 2016-12-29 11:28:13 | 显示全部楼层
同问,楼主怎么解决的
发表于 2017-2-3 13:16:45 | 显示全部楼层
回复 5# atlandis
   http://bbs.eetop.cn/viewthread.php?tid=553702&extra=&page=1
用这个license生成器可以,注意不要瞎鸡巴乱改notice,我就是因为乱改了一发出了这个错
发表于 2017-2-4 14:43:19 | 显示全部楼层
回复 6# churchmice
   我这里是偶尔会出错,应该不是license的问题吧,比如跑10个case,可能有一个出错
发表于 2017-8-14 20:45:21 | 显示全部楼层
回复 1# 飞扬紫百合
   楼主这个问题解决了吗?
发表于 2018-2-3 12:08:01 | 显示全部楼层
修改网卡名解决 Dumping VCS Annotated Stack 问题
发表于 2019-11-26 23:11:39 | 显示全部楼层
thanks
GMT+8, 2025-10-2 20:29 , Processed in 0.021594 second(s), 5 queries , Gzip On, Redis On.
