查看: 3670|回复: 3
[求助] chip window size=seal ring window edge ?
发表于 2015-4-15 15:19:54 | 显示全部楼层 |阅读模式
看SMIC design rule说:BORDER layer size should be exactly same with the seal ring window edge if seal ring has been added by designers;又说:BORDER  layer  size  should  be  exact  same  with  chip  window  size  in LDDI form (chip window size when tape-out).
是不是就是说:tape-out时候的chip window size=seal ring window edge ?
还有就是流片时芯片的面积大小怎么算?就是chip window size吗?
发表于 2015-4-15 17:31:31 | 显示全部楼层
当你没有sealring的时候,bordersize就是最外面的border层(127)占用的window size,
通常也就是LDDI 里面填的size,而且会备注: without seal ring , added by smic standard sealring
当你含有sealring的时候,border要包含sealring,LDDI里面也是填这个size,
并且备注: with sealring, no need added again by smic
 楼主| 发表于 2015-4-18 13:22:58 | 显示全部楼层
回复 2# icfbicfb
LDDI 指定是什么?
发表于 2015-4-18 19:39:39 | 显示全部楼层
layout design database information , 就是mask tooling form
GMT+8, 2025-8-20 09:09 , Processed in 0.014640 second(s), 5 queries , Gzip On, Redis On.
