楼主: schwang
[求助] Charge pump IC design
发表于 2015-4-11 03:16:27 | 显示全部楼层
http://www.amazon.com/Charge-Pump-Design-Feng-Pan/dp/0071836772
Published on 2/19/2015
发表于 2015-4-11 03:18:32 | 显示全部楼层
发表于 2015-4-11 03:20:25 | 显示全部楼层
Charge Pump IC Design Hardcover – February 19, 2015
Design state-of-the-art charge pumps
Charge Pump IC Design delivers an advanced systematic approach to charge pump circuit design—from building blocks to final pump. The book describes how to achieve high power efficiency and low supply noise. Negative feedback control, compensation, and stability are discussed and real-world design examples with schematics are included. The proven techniques presented in this practical, cutting-edge guide will help you to provide the efficient power conversion needed for today’s portable electronic devices.
Editorial Reviews
About the Author
Feng Pan received his BS degree in EECS from The University of California, Berkeley, and MS in Electrical Engineering from Stanford University. He is a Stanford Certified Program Manager (SCPM), and is currently working as a director of NSG at Micron Technology, Inc., on 3D VNAND technology. Mr. Pan previously held various senior management and leadership positions at SanDisk and AMD. Mr. Pan is coauthor of Charge Pump Circuit Design, and has 51 granted patents related to power management, LDO, charge pump architectures, charge pump regulations and applications, ADC design, op-amp designs, and NAND/NOR flash memory designs.
发表于 2015-4-11 20:53:57 | 显示全部楼层
Feng Pan的新书,二楼的不对
发表于 2015-4-13 23:44:28 | 显示全部楼层
谢谢,一本好书
发表于 2015-4-15 21:36:13 | 显示全部楼层
楼主说的是2015的,这怎么是2006的?
lwjee 发表于 2015-4-9 22:21
同问
发表于 2015-4-17 19:04:53 | 显示全部楼层
charger pump 用于USB 开关
发表于 2015-4-17 21:47:31 | 显示全部楼层
看一下
发表于 2015-4-28 21:32:10 | 显示全部楼层
谢谢分享
发表于 2015-6-6 08:47:40 | 显示全部楼层
GMT+8, 2025-12-20 01:47 , Processed in 0.430091 second(s), 3 queries , Gzip On, Redis On.
