楼主: min4max
Cadence IC最近两个Hotfix中新增加的用户使用条款!!!必须提请关注!!!
发表于 2015-4-14 17:29:53 | 显示全部楼层
So a new patch may need to crack 2 places?
发表于 2015-6-20 12:43:57 | 显示全部楼层
hello,
I think there is the problem with patching. I install IC 6.16.100 ISR11 on Scientific Linux 6.6:
1. I don't patch >>> the program can't start-up  because "111" license feature can't check-out.
2. I patch >>> the program start-up  and "111" license feature is check-out and then it's crashed.
So it's possibility that Cadence has used new technic to detect the fake license/ patching
发表于 2015-10-19 13:51:12 | 显示全部楼层
Hi.
I also see the same on OpenSuse 13.2.
Without the patch virtuoso doesn't patch and after patching it crashes.
It only happens on IC6.1.6.100+. MMSIM14.1 is working fine with the patch.
There are rumors in other forums of Cadence using vilabs protection (spy) software. I don't know if it's true but I'm concerned.
http://bbs.eetop.cn/thread-561287-1-1.html
发表于 2015-10-19 22:51:48 | 显示全部楼层
Thank you.
发表于 2017-2-9 14:52:18 | 显示全部楼层
Thanks
发表于 2017-4-17 17:18:32 | 显示全部楼层
是否可以切断网络连接cadence,在hosts添加DNS,软件联络cadence的网址故意指向错误的IP,是否可以解决?
发表于 2023-2-10 15:53:22 | 显示全部楼层
不是吧,现在IC618也是可以正常用的啊
GMT+8, 2025-12-22 05:46 , Processed in 0.021698 second(s), 2 queries , Gzip On, Redis On.
