楼主: min4max
Cadence IC最近两个Hotfix中新增加的用户使用条款!!!必须提请关注!!!
发表于 2015-4-7 12:38:13 | 显示全部楼层
If you able to install this Hotfix on a RHEL machine, then patch it, you will see that's gonna work..
Another guy has metioned this problem ( I believe he's using legal license ) on CentOS machine so trouble is common..
I personally IC 6.15 that is more stable ( at least with GoldenGate ) and IC6.16 doesn't bring any additional shit..
发表于 2015-4-7 13:10:57 | 显示全部楼层
看来还是需要从Flexlm SDK入手开发出完美的lmcrypt来制作与Cadence官方发布的license.dat一致的license.dat,这样就不必再经过patch修改软件。
这点几乎不可能,ECC加密的,╮(╯_╰)╭
发表于 2015-4-7 19:37:30 | 显示全部楼层
期待新的patcher
发表于 2015-4-7 20:04:59 | 显示全部楼层
回复 11# T.Maxwell
Thank you for your elaboration!
发表于 2015-4-7 20:08:33 | 显示全部楼层
多谢了!!不过上次IC616 的 IC06.16.100  HOTFIX 我用以前的坛子上的patch没有用起来。有人用起来的吗?
发表于 2015-4-7 20:11:47 | 显示全部楼层
回复 11# T.Maxwell
Thank you for your elabration!
I used patch tool from the forum but it did not work for IC06.16.100 since then. Would you mind share your patcher?
Thanks a lot!
发表于 2015-4-7 20:12:36 | 显示全部楼层
Hello Maxwell
Thanks a lot!
发表于 2015-4-11 22:18:14 | 显示全部楼层
从分析来看,后续cadence工具会采用自校验
发表于 2015-4-13 12:37:56 | 显示全部楼层
以后看样子IC616得跟以前的synplify一样,crc和pubkey同时解决才行。
发表于 2015-4-14 05:00:23 | 显示全部楼层
OK, it's a new protection scheme.Standard pubkey_verify does not work anymore because the main program checks itself ( I think a new subroutine).Latest hotfix of Assura 6.16 works under Virtuoso design environment otherwise "avview" creates the same problem (crashing).
Take care and save well version 6.1.6.090 until a smart guy finds solution..
If someone is expert on assembler, he can find a solution..
GMT+8, 2025-12-10 04:35 , Processed in 0.021304 second(s), 4 queries , Gzip On, Redis On.
