查看: 3485|回复: 4
[求助] on chip Digital Isolators for flyback
发表于 2015-4-1 17:16:01 | 显示全部楼层 |阅读模式
who desgn fluxLink or use cmos  Digital Isolators   for pwm system , like flyback ..
flyback need pc817 tl431 ..
some design use primary side control , but have many problem on burst mode .  light load ..
dynamic response issue ..
how about this
PI fluxLink .
发表于 2017-1-14 08:52:44 | 显示全部楼层
    找到 两类
1. on-chip cap isolator
2. chip-chip 间 ac couple 或是透过 bonding wire 沟通
多数 1G ~12G Hz .
12 Gbs Chip-to-Chip AC Coupled Transceiver.pdf (365.83 KB , 下载次数: 27 )
14Gbs 32mw ac couple in 90nm.pdf (1013.95 KB , 下载次数: 22 )
2011-12-AICSP2006 ISO amp in SOI cmos.pdf (1.29 MB , 下载次数: 24 )
2011-12-TCASII Capacitive Inter-Chip Data and Power Transfer for 3-D VLSI .pdf (754.9 KB , 下载次数: 31 )
也说算 isolator .
不过 CHIP 间真的是isolator  但须要沟通  3D IC 使用方式
发表于 2017-12-31 00:09:44 | 显示全部楼层
这部分资料还可以看
发表于 2018-12-3 15:04:42 | 显示全部楼层
kan kan.............
发表于 2019-1-30 18:56:03 | 显示全部楼层
GMT+8, 2025-11-15 17:38 , Processed in 0.027175 second(s), 7 queries , Gzip On, Redis On.
