楼主: ald_syn_cad
[Req] Aldec 2015 tools
发表于 2015-4-2 00:50:22 | 显示全部楼层
ALINT-PRO-CDC  (Win32).
Alint_CDC_2015.01_win32.rar
147 Bytes, 下载次数: 85 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2015-4-2 02:09:56 | 显示全部楼层
发表于 2015-4-2 08:34:15 | 显示全部楼层
回复 11# adialbu
Hi  adialbu :
Could you please check your Riviera crack for 2015.2 by running the vhdl project "counter"?  it seems there is no output signal Y.
thanks,
 楼主| 发表于 2015-4-2 16:57:45 | 显示全部楼层
@usb123
I think there would be a bug because most of the VHDL samples have this issue.
发表于 2015-4-2 18:57:05 | 显示全部楼层
I do not think it is the software bug. The crack version has this problem since 2014. It seems ok for 2013 version.
发表于 2015-4-2 21:47:20 | 显示全部楼层
I do not think it is the software bug. The crack version has this problem since 2014. It seems ok fo ...
usb123 发表于 2015-4-2 18:57
    This crack is useful for riviera 2015,  NO abnormal quit.
But I have not tested vhdl code.
 楼主| 发表于 2015-4-3 02:35:51 | 显示全部楼层
The crack does not cause any problem. It patches the soft like the version 2009 published by rl-team with just 6 byte modification to the target (17) files.
If you simulate the CB4CE entity (from libraries window) manually and stimulate the input pins (from stimuli window) manually you'll see that it works fine but I admit that there is a script error, why I don't know.
发表于 2015-4-4 00:39:06 | 显示全部楼层
I always go back to modelsim which I now license - it runs on all platforms and such, but you can't beat the editor on aldec - I also like using the waveform viewer for dumps from identify debugger. Hardly though justification for the price tag
 楼主| 发表于 2015-4-4 00:52:15 | 显示全部楼层
Unfortunately VHDL is not the case, most of the other projects have this problem.
发表于 2015-4-26 07:59:47 | 显示全部楼层
ald_syn_cad 发表于 2015-4-4 00:52
    Could you please make the license with new features of ALINT_PRO_CDC  ?
GMT+8, 2025-12-14 18:42 , Processed in 0.019112 second(s), 5 queries , Gzip On, Redis On.
