查看: 5875|回复: 3
[解决] XILINX FPGA下载失败,release done bit is NOT 1
发表于 2015-3-24 22:20:30 | 显示全部楼层 |阅读模式
我有一块V6的板子,下载的时候总是失败,希望能有人帮忙解决done.
INFO:iMPACT:2218 - Error shows in the status register, release done bit is NOT 1.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 0001 0111 0000 0000 0000 1100 0100
PROGRESS_END - End Operation.
Elapsed time =     21 sec.
'1': Reading bootsts register contents...
[0] VALID_0 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         0
[1] FALLBACK_0 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[2] IPROG_0 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION          :         0
[3] WTO_ERROR_0 - WATCHDOG TIME OUT ERROR                                  :         0
[4] ID_ERROR_0 - FPGA DEVICE IDCODE ERROR                                  :         0
[5] CRC_ERROR_0 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                      :         0
[6] WRAP_ERROR_0 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR             :         0
[7] HMAC_ERROR_0 - HMAC ERROR                                              :         0
[8] VALID_1 - ERROR OR END OF STARTUP (EOS) DETECTED                       :         0
[9] FALLBACK_1 - FALLBACK TRIGGERED RECONFIGURATION                        :         0
[10] IPROG_1 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION         :         0
[11] WTO_ERROR_1 - WATCHDOG TIME OUT ERROR                                 :         0
[12] ID_ERROR_1 - FPGA DEVICE IDCODE ERROR                                 :         0
[13] CRC_ERROR_1 - CYCLIC REDUNDANCY CHECK (CRC) ERROR                     :         0
[14] WRAP_ERROR_1 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR            :         0
[15] HMAC_ERROR_1 - HMAC ERROR                                             :         0
'1': Reading status register contents...
[0] CRC ERROR                                                              :         0
[1] DECRYPTOR ERROR                                                        :         0
[2] PLL LOCK STATUS                                                        :         1
[3] DCI MATCH STATUS                                                       :         1
[4] END OF STARTUP (EOS) STATUS                                            :         0
[5] GTS_CFG_B STATUS                                                       :         0
[6] GWE STATUS                                                             :         0
[7] GHIGH STATUS                                                           :         1
[8] MODE PIN M[0]                                                          :         0
[9] MODE PIN M[1]                                                          :         1
[10] MODE PIN M[2]                                                         :         1
[11] INIT_B INTERNAL SIGNAL STATUS                                         :         1
[12] INIT_B PIN                                                            :         0
[13] DONE INTERNAL SIGNAL STATUS                                           :         0
[14] DONE PIN                                                              :         0
[15] IDCODE ERROR                                                          :         0
[16] SECURITY ERROR                                                        :         0
[17] SYSTEM MONITOR OVER-TEMP ALARM STATUS                                 :         0
[18] CFG STARTUP STATE MACHINE PHASE                                       :         0
[19] CFG STARTUP STATE MACHINE PHASE                                       :         0
[20] CFG STARTUP STATE MACHINE PHASE                                       :         0
[21] RESERVED                                                              :         0
[22] SPI FLASH SELECT PIN FS[0]                                            :         0
[23] SPI FLASH SELECT PIN FS[1]                                            :         0
[24] SPI FLASH SELECT PIN FS[2]                                            :         1
[25] CFG BUS WIDTH DETECTION                                               :         1
[26] CFG BUS WIDTH DETECTION                                               :         0
[27] RESERVED                                                              :         0
[28] HSWAPEN PIN                                                           :         0
[29] BAD PACKET ERROR                                                      :         1
[30] RESERVED                                                              :         0
[31] EFUSE BUSY STATUS                                                     :         0
 楼主| 发表于 2015-3-25 09:31:22 | 显示全部楼层
寻求高手解答
发表于 2015-8-6 12:54:17 | 显示全部楼层
see see
发表于 2022-2-25 07:16:24 | 显示全部楼层
thank you very much
GMT+8, 2025-9-19 21:14 , Processed in 0.015799 second(s), 4 queries , Gzip On, Redis On.
