楼主 |
发表于 2015-3-24 19:12:05
显示全部楼层
看来这个论坛里android驱动的人不多啊,我自己找个python脚本,可以将android_log和kernel_log的时间对应起来
- import time
- import datetime
- import sys
- import getopt
- import os
- a_time = None
- s_second = None
- s_microsecone = None
- abs_time = 0.0
- inputfile = None
- outputfile = None
- def usage():
- print('''Help Information:
- -h, --help: Show help information
- -i, --inputfile: input file to parse
- -o, --outputfile: output fiel parsed
- def calc_delta(stream):
- global s_second
- global s_microsecond
- global a_time
- global outfile
- begin_index = None
- end_index = None
- delta_second = 0
- delta_mircosecond = 0
- delta_time = 0
- d_time = None
- new_line = None
- if a_time ==None:
- print("Can't convert to android time")
- exit(-1)
- for line in stream:
- if line:
- try:
- begin_index = line.index('[')
- end_index = line[begin_index+1:].index(']')+begin_index+1
- time_string = line[begin_index + 1 :end_index]
- [d_second,d_microsecond] = time_string.split('.')
- delta_second = int(int(d_second) - int(s_second))
- delta_microsecond = int(int(d_microsecond)-int(s_microsecond))
- delta_time = datetime.timedelta(seconds=delta_second,microseconds=delta_microsecond)
- d_time = a_time + delta_time
- new_line = d_time.strftime("%m-%d %H:%M:%S.%f")+' ' + line
- outputfile.write(new_line)
- except:
- outputfile.write(line)
- def get_atime(stream):
- global s_second
- global a_time
- a_time_op = None
- end_index = None
- if line:
- a_time_op = line.find('android time')
- if a_time_op>=1:
- date_string = line[a_time_op+13:].strip()
- abs_time = line[begin_index + 1 :end_index]
- [s_second,s_microsecond] = abs_time.split('.')
- a_time = datetime.datetime.strptime(date_string, "%Y-%m-%d %H:%M:%S.%f")
- break
- def main(argv):
- global inputfile
- global outputfile
- inputpath = None
- outputpath = None
- try:
- opts, args = getopt.getopt(argv,"hi:o:",["help","inputfile=","outputfile="])
- except getopt.GetoptError:
- usage()
- sys.exit(2)
- for opt, arg in opts:
- if opt in ("-h", "--help"):
- usage()
- sys.exit()
- if opt in ("-i", "--inputfile"):
- inputpath = arg
- if opt in ("-o", "outputfile"):
- outputpath = arg
- if inputpath == None:
- usage()
- sys.exit()
- if outputpath == None:
- outputpath = os.getcwd()+"/out.txt"
- inputfile = open(inputpath, 'r')
- outputfile = open(outputpath, 'w')
- get_atime(inputfile)
- inputfile.seek(0)
- calc_delta(inputfile)
- inputfile.close()
- outputfile.close()
- if __name__ == "__main__":
- main(sys.argv[1:])
复制代码 |
