查看: 8168|回复: 6
centOS7安装好IC616和MMSIM、SPB166之后报这个错,该怎么解决呢
发表于 2015-3-22 10:28:22 | 显示全部楼层 |阅读模式
[root@zbcom yuezhengzikang]# su yuezhengzikang
bash: /home/cadence/INCISIVE142/kits/VerificationKit/env.sh: No such file or directory
bash-4.2$ virtuoso &
[1] 4378
bash-4.2$ WARNING: HOST <zbcom.com> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
virtuoso:   ERROR: The command /home/cadence/IC616/share/oa/bin/sysname returned an error status:
                            unknown
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
[1]+  Exit 1                  virtuoso
bash-4.2$
发表于 2015-3-22 18:35:19 | 显示全部楼层
系统不支持吧
 楼主| 发表于 2015-4-7 12:50:29 | 显示全部楼层
我也是抱这个错,后来索性换回windows7来了
发表于 2015-4-7 20:59:43 | 显示全部楼层
CentOS7尚未被支援....我的解決方式:
啟動Tools(ic616,spb166...)之前
bash shell輸入下面兩行或者 .bashrc(在home user目錄下,顯示隱藏檔,可看到.bashrc file)直接加入這兩行 !!
unset OA_HOME
export OA_UNSUPPORTED_PLAT=linux_rhel50_gcc44x
您試試看可不可行 !!
提供參考 !!
发表于 2017-4-12 09:42:45 | 显示全部楼层
回复 4# lik4965
   请问是在linux系统下修改.bashrc文件么?
发表于 2017-4-14 14:11:53 | 显示全部楼层
请问一下你有没有installscape的安装包,能发我一份吗?
发表于 2018-11-29 19:33:43 | 显示全部楼层
有解决问题了吗
GMT+8, 2025-12-30 08:46 , Processed in 0.018588 second(s), 6 queries , Gzip On, Redis On.
