查看: 3234|回复: 3
[求助] 求会Perl的大神帮助,如何写一个txt转bin格式的Perl脚本???
发表于 2015-3-19 23:08:23 | 显示全部楼层 |阅读模式
RT,小弟急需一个perl脚本把txt格式的文件转换为bin格式,就是通常keil51 ARM编译器编译出来的bin文件。求高手指导该怎么写?还是说CPAN有写好的模块以供使用。对PERL语言的使用停留在<Perl快速入门[第六版]>的基础上。再次请大神出山指点迷津呀!!!
 楼主| 发表于 2015-3-20 10:04:30 | 显示全部楼层
没有人回复呀,自己顶起来
发表于 2015-4-7 19:17:00 | 显示全部楼层
#!perl -w
# Usage: convert.pl [source file] [destination file]
#    If we donot provide source file, STDIN will be used as source.
#    If we donot provide destination file, a file named a.out will be used as output.
if ($#ARGV != 1)
    print "Use a.out as default output file.\n";
    $destfile = "a.out";
else
    $destfile = $ARGV[1]; #using user defined output file
open OUTF, ">$destfile" or die "Can't open $destfile for writing!\n";
binmode(OUTF);
while (<>)
    for $chunk (split(/ /, $_))
        print OUTF pack("H2", $chunk); #use pack function to write data in binary format
close(OUTF);
发表于 2015-4-22 16:26:12 | 显示全部楼层
原来写过一个,哈哈
GMT+8, 2025-11-30 20:33 , Processed in 0.015961 second(s), 5 queries , Gzip On, Redis On.
