查看: 1983|回复: 4
[招聘] 【NVIDIA社招】英伟达上海热招后端工程师
发表于 2015-3-16 16:49:05 | 显示全部楼层 |阅读模式
一.公司简介
        NVIDIA (英伟达™)(www.nvidia.cn)公司(纳斯达克代码:NVDA)是全球视觉计算技术的行业领袖及GPU(图形处理器)的发明者。作为高性能处理器的GPU可在工作站、个人计算机、游戏机和移动设备上生成令人叹为观止的互动图形效果。公司在全球拥有超过8000名员工,总部在加利福尼亚州圣克拉拉。
工作地址:上海研发中心【上海申江路5709号(秋月路26号)矽岸国际2号楼】
二.投递方式
简历发送至HR(Yvette SHEN)邮箱:yvettes@nvidia.com
三.职位详情
ASICPhysical Design engineer
As asenior member of our ASIC-PD team, you'll be working on streamlining the chipinfrastructure process across product designs, focusing on full chip layoutplanning (partitioning, planning clock distribution and other structure,methodology), partition/full chip timing closure (primetime scripts, othertools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
Chip integration and netlist generation
-Synthesis, Formal verification, netlist qualitycheck
Work in conjunction with Place and RouteEngineers to achieve timing closure for both partition level and full chiplevel
Develop and enhance entire timing flow fromfrontend (pre-layout) to backend (post-layout) at both chip and block level.
Develop custom timing scripts usingtcl/primetime for clock skew analysis, special circuits such as clock dividers,core logic <-> IO macros interfaces such as PCI-E, Frame-Buffer/Memory,TMDS, etc.
Develop flow to physically partition andfloorplan the entire chip.
Developscripts for performing ECO's.
MINIMUMREQUIREMENTS:
BS or MS in Electrical Engineering or ComputerScience
Above 3 years of relevant ASIC experienceideally with a focus in the chip integration /synthesis/formal and timingclosure
- Excellent scripts skills
- Excellent written and verbal communicationskills in English
- Ability to multiplex many issues, setpriorities, and work in a team environment
- Keep up to date with leading edge technologies
 楼主| 发表于 2015-3-18 18:46:23 | 显示全部楼层
 楼主| 发表于 2015-3-20 15:46:58 | 显示全部楼层
 楼主| 发表于 2015-3-23 17:27:05 | 显示全部楼层
【NVIDIA社招】【NVIDIA社招】【NVIDIA社招】
 楼主| 发表于 2015-3-30 17:08:27 | 显示全部楼层
大家赶紧投递啦!年后新出炉的职位!
GMT+8, 2025-12-28 00:34 , Processed in 0.020323 second(s), 6 queries , Gzip On, Redis On.
