查看: 4647|回复: 2
[求助] 安装CST2014时遇到的问题 求助!!
发表于 2015-3-13 13:49:15 | 显示全部楼层 |阅读模式
求大神指导 安装CST2014时出现了下面问题 之前步骤是按照教程来的1) run CST License Manager and Stop Service, close CST License Manager
2) edit license.dat: change <pc-name> (with lower case) in 1-st line with your real HostName
3) put license.dat to \Program Files\CST STUDIO SUITE 2013\ folder
4) put CSTpatcher.exe to \Program Files\CST STUDIO SUITE 2013\ folder and run it there
5) run CST License Manager and Start Service, close CST License Manager
6)After that , when you run CST  choose : ''point to an existing CST license server system''
7)Then, type your pc-name on it(You should type with lower case ) , then OK  & Enjoy it
进行到第五步的时候无法启动了  license是按照要求改的 不过我电脑的主机名附带大写字母 我用大小写均试过一次还是无法启动
求大神给个解决的方法 感激不尽
[img]file:///C:\Users\asus\AppData\Roaming\Tencent\Users\646767021\QQ\WinTemp\RichOle\UA``T`~][X)859AO3EJ364P.jpg[/img]
发表于 2015-3-22 12:32:48 | 显示全部楼层
我是到最后一步填入那个主机的名后,还是没法打开。现在正在苦闷呢。
发表于 2017-3-14 11:24:24 | 显示全部楼层
同求解答
GMT+8, 2025-12-14 03:09 , Processed in 0.019780 second(s), 7 queries , Gzip On, Redis On.
