查看: 2459|回复: 0
[求助] DCD初始化问题求助
发表于 2015-3-7 11:46:14 | 显示全部楼层 |阅读模式
运行这个程序,为什么用DCD不能按照要求将src中的数据初始化为1,2,3,4,....而全部是0?
Stack_Size      EQU     0x00000400
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x00000200
num
EQU 20
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
AREA RESET, DATA, READONLY
DCD __initial_sp
DCD Reset_Handler
DCD src
AREA Block, CODE, READONLY
ENTRY
;CODE32
Start
Reset_Handler  PROC
EXPORT Reset_Handler
[WEAK]
ENDP
;LDR R0,=src
;LDR R1,=dst
;LDR R2,[R0,#4]
;MOV R3,R0
;STR R2,[R1]
;B .
            LDR     r0, =src                 ; r0 = pointer to source block
            LDR     r1, =dst                 ; r1 = pointer to destination block
            MOV     r2, #num                 ; r2 = number of words to copy
wordcopy
            LDR     r3, [r0], #4             ; load a word from the source and
            STR     r3, [r1], #4             ; store it to the destination
            SUBS    r2, r2, #1               ; decrement the counter
            BNE     wordcopy                 ; ... copy more
stop
            ;MOV     r0, #0x18                ; angel_SWIreason_ReportException
            ;LDR     r1, =0x20026             ; ADP_Stopped_ApplicationExit
            ;SVC     #0x123456                ; ARM semihosting (formerly SWI)
B .
AREA BlockData, DATA, READWRITE
src
DCD 1,2,3,4,5,6,7,8,1,2,3,4,5,6,7,8,1,2,3,4
dst     DCD 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
END
GMT+8, 2025-12-30 03:44 , Processed in 0.019597 second(s), 8 queries , Gzip On, Redis On.
