查看: 2725|回复: 3
[求助] 有关APB的一个菜鸟问题
发表于 2015-3-3 14:29:37 | 显示全部楼层 |阅读模式
在看APB的手册时有以下一句话:
It is recommended that the address and write signals are not changed immediately after a transfer but remain stable until another access occurs.
让我疑惑的是为什么只建议address 和 write 两个信号,而不包含data信号呢?
按说在下次传输之前data也没用啊,完全可以不管它。
问题2:
PREADY can take any value when PENABLE is LOW. This ensures that peripherals that have a fixed two cycle access can tie PREADY HIGH.
这什么意思?完全不懂。尤其是:peripherals that have a fixed two cycle access
小弟在这里多谢了~~~
发表于 2015-3-8 18:22:13 | 显示全部楼层
顶起,让大神看到
 楼主| 发表于 2015-3-11 13:40:33 | 显示全部楼层
再问一个,AXI spec上还有一句话也让我看醉了:
An interconnect between devices is equivalent to another device with symmetrical master and slave ports to which real master and slave devices can be connected.
是什么意思
 楼主| 发表于 2015-3-11 13:48:58 | 显示全部楼层
register slice怎么解释?
GMT+8, 2025-11-21 02:00 , Processed in 0.022229 second(s), 7 queries , Gzip On, Redis On.
