查看: 3103|回复: 2
[解决] rhel6.5 IC5141启动时出错解决办法
发表于 2015-2-2 15:45:32 | 显示全部楼层 |阅读模式
我在rhel6.5安装ic5141,启动 icfb&时出下如下 error:
X Error of failed request:  BadName (named color or font does not exist)
  Major opcode of failed request:  45 (X_OpenFont)
解决方法:
system-->Administration-->Add/Remove Software
search 输入: iso8859
由于不清楚原理,把没有装的全装了后,就好了。
 楼主| 发表于 2015-2-3 01:00:19 | 显示全部楼层
刚才研究了一下:只要安装: ISO8859-9-100dpi fonts                                   ISO8859-9-75dpi fonts
                                   a set of 75dpi ISO-8859-1 fonsts for X
                   下次再实验一下!
发表于 2015-3-22 11:01:59 | 显示全部楼层
回复 2# pctanyicheng
    What is the RHEL6.5 version 64bit or 32bit for IC5141?
GMT+8, 2025-9-16 14:41 , Processed in 0.019635 second(s), 6 queries , Gzip On, Redis On.
