查看: 4222|回复: 2
[求助] SVA 中的bind为何不起作用?
发表于 2015-1-28 07:39:13 | 显示全部楼层 |阅读模式
module xx(select,a,b,c,o);
  input [1:0]select;
  input [4:0] a,b,c;
  output [4:0]o;
  reg [4:0]o;
  always@(a or b or c or select)
  begin
    case(select)
      1=a;
      2=b;
      3=c;
default:o=a;
endcase
  end
  always_comb
  begin
   assert_select: assert ((select == 1)&&(o==a));
  end
endmodule
module testbench;
  reg  [1:0]select;
  reg [4:0]a,b,c;
  wire [4:0] o;
  reg clk,rst_n;
  integer i;
  initial begin
    a=4;b=5;c=6;
    rst_n = 0;
    clk = 0;
    #2;
    rst_n= 1;
    #3;
    clk = 1;
    for(i=0;i<100;i=i+1)
    #5 clk = ~clk;
$stop;
  end
always @(posedge clk or negedge rst_n)
begin
if(~rst_n)
select <=0;
else
select <=  select+1;
end
xx xx_u(select,a,b,c,o);
bind  xx  xx_asser_chk  chk_u(clk,select,a,b,c,o);
endmodule
module  xx_asser_chk(clk,select,a,b,c,o);
  input clk;
  input [1:0]select;
  input [4:0] a,b,c;
  input [4:0]o;
property chk_sel;
@(posedge  clk)(select == ($past(select)  +  1));
endproperty
assert_sel: assert property (chk_sel);
  cover_sel: cover property (chk_sel);
endmodule
在modelsim中运行:
vlog -sv -cover bset +acc=a xx.sv
vsim -assertcover -coverage testbench
run 60ns
运行结果:fail_count、pass_count、active count全部为0,为什么呀?
 楼主| 发表于 2015-1-28 22:36:33 | 显示全部楼层
回复 1# crystal_duan
  input [1:0]select;
  input [4:0] a,b,c;
  output [4:0]o;
  reg [4:0]o;
  begin
    case(select)
      1=a;
      2=b;
      3=c;
default:o=a;
endcase
  end
  always_comb
  begin
  end
endmodule
  input clk;
  input [1:0]select;
  input [4:0] a,b,c;
  input [4:0]o;
property chk_sel;
@(posedge  clk)((select == 1)&&(o==a));// (select == ($past(select)  +  1));
endproperty
endmodule
module testbench;
  reg  [1:0]select;
  reg [4:0]a,b,c;
  wire [4:0] o;
  reg clk,rst_n;
  integer i;
  initial begin
    a=4;b=5;c=6;
    rst_n = 0;
    clk = 0;
    #2;
    rst_n= 1;
    #3;
    clk = 1;
    #5 clk = ~clk;
$stop;
  end
begin
if(~rst_n)
select <=0;
else
select <=  select+1;
end
property sel_seq;
    @(posedge clk)(select ==0)|=>  (select ==1)|=> (select==2)|=> (select==3)|=> (select==0);
  endproperty
  assert_seq: assert property (sel_seq);
  cover_seq: cover property (sel_seq);
property chk_sel1;
@(posedge  clk) if($past(select)  ==  3)(select == 0)else  if($isunknown($past(select)))(select ==  0) else(select == ($past(select)  +  1));
endproperty
assert_sel1: assert property (chk_sel1);
  cover_sel1: cover property (chk_sel1);
endmodule
发表于 2015-2-27 17:23:49 | 显示全部楼层
回复 2# crystal_duan
   你确定能bind?你bind的那个模块xx,可是没有clk的呢。端口声明不一样吧,居然没报错?
GMT+8, 2025-12-27 21:18 , Processed in 0.019934 second(s), 5 queries , Gzip On, Redis On.
