查看: 2693|回复: 6
Olympus License Or Mentor Feature Line
发表于 2015-1-18 14:52:33 | 显示全部楼层 |阅读模式
Please Comment The Feature Line Of Olympus.. Will Try For Generating License...
发表于 2015-1-18 16:10:58 | 显示全部楼层
有patch了吗?
发表于 2015-1-18 16:48:05 | 显示全部楼层
谢谢楼主,先下载下来看看
发表于 2015-1-19 06:38:35 | 显示全部楼层
回复 3# peternj
灌水也要看清楚再说。人家也是请求贴,你何来下载??
发表于 2015-1-19 09:39:27 | 显示全部楼层
这俩feature,几乎搞定所有mentor tools
  1. mgc_s
  2. mentorall_s
    复制代码
发表于 2015-1-20 16:22:27 | 显示全部楼层
回复 5# snk88
能不能用呢?
发表于 2016-5-26 09:04:37 | 显示全部楼层
info UI180: Type "olympus -help all" to display the full command help.
warning UI705: 'olympus -product' specified value was ignored.
error UI300: failed to check out the license key 'pnrdatabase': Cannot get license
info UI155: Olympus-SoC terminated with exit status of 1 (failure
need  license key 'pnrdatabase' , can you generate this license feature ??
GMT+8, 2025-12-21 13:36 , Processed in 0.019476 second(s), 5 queries , Gzip On, Redis On.
