查看: 6218|回复: 17
[资料] Compound Semiconductor Device Modelling
发表于 2015-1-7 03:14:58 | 显示全部楼层 |阅读模式
1447120507.pdf (12.23 MB , 下载次数: 468 )
Compound semiconductor devices form the foundation of solid-state microwave and optoelectronic technologies used in many modern communication systems. In common with their low frequency counterparts, these devices are often represented using equivalent circuit models, but it is often necessary to resort to physical models in order to gain insight into the detailed operation of compound semiconductor devices. Many of the earliest physical models were indeed developed to understand the 'unusual' phenomena which occur at high frequencies. Such was the case with the Gunn and IMPATI diodes, which led to an increased interest in using numerical simulation methods. Contemporary devices often have feature sizes so small that they no longer operate within the familiar traditional framework, and hot electron or even quantum- mechanical models are required. The need for accurate and efficient models suitable for computer aided design has increased with the demand for a wider range of integrated devices for operation at microwave, millimetre and optical frequencies. The apparent complexity of equivalent circuit and physics-based models distinguishes high frequency devices from their low frequency counterparts . . Over the past twenty years a wide range of modelling techniques have emerged suitable for describing the operation of compound semiconductor devices. This book brings together for the first time the most popular techniques in everyday use by engineers and scientists. The book specifically addresses the requirements and techniques suitable for modelling GaAs, InP. ternary and quaternary semiconductor devices found in modern technology.
发表于 2015-1-7 19:58:06 | 显示全部楼层
下来看看
发表于 2015-1-9 16:00:06 | 显示全部楼层
model
发表于 2015-3-20 21:41:01 | 显示全部楼层
下来看看
发表于 2015-12-9 14:11:27 | 显示全部楼层
还是1993年出版的书,可想而知,我们在封装方面曾经落后别人多少年
发表于 2016-3-30 13:42:13 | 显示全部楼层
这个资料很珍贵耶
谢谢楼主分享
发表于 2016-3-31 23:01:08 | 显示全部楼层
回复 1# pyprus
    好东西,学习一下。
发表于 2016-4-6 22:12:34 | 显示全部楼层
学习一下。
发表于 2017-1-3 18:08:22 | 显示全部楼层
回复 1# pyprus
谢谢啊暗暗啊啊
发表于 2017-4-7 18:42:40 | 显示全部楼层
下来看看!!!
GMT+8, 2025-9-15 15:39 , Processed in 0.091441 second(s), 6 queries , Gzip On, Redis On.
