查看: 3351|回复: 7
[求助] skill syntax error
发表于 2014-12-30 09:50:53 | 显示全部楼层 |阅读模式
I uesd the skill see below :
but When I load "CCSattachLabels.il"  in  CIW
there are the syntax error
  syntax error in line 5 column 3 of file) ,  What is the problem ?
procedure( CCSattachLabels()
   let( (cv allLabels x1 y1 box inst)
      cv=geGetWindowCellView()
      allLabels=setof(x cv~>shapes x~>objType=="label")
      foreach( label allLabels
         x1=car(label~>xy)
         y1=cadr(label~>xy)
         box=list(x1:y1 x1+0.001:y1+0.001)
         inst=car(dbProduceOverlapInst(cv box))
         leAttachFig(label inst)
         printf("Attached label %s at %L to inst %s\n" label~>theLabel label~>xy inst~>name)
      ) ;foreach
   ) ;let
) ;procedure
发表于 2014-12-30 13:48:30 | 显示全部楼层
没有什么错吧
回复 1# james0933
发表于 2014-12-30 14:24:16 | 显示全部楼层
error?  where? 解决了吗?
发表于 2014-12-31 10:37:11 | 显示全部楼层
看着没错啊
 楼主| 发表于 2014-12-31 11:25:33 | 显示全部楼层
回复 3# leshi
    in  CIW
  syntax error
 楼主| 发表于 2014-12-31 11:26:12 | 显示全部楼层
回复 2# xxmule
      in  CIW
  syntax error
发表于 2015-3-1 13:29:08 | 显示全部楼层
帮你改了一下 貌似可以了
procedure( attach()
   let( (cv allLabels x1 y1 box inst x)
      cv=geGetSelectedSet()
      cv1 =geGetWindowCellView()
allLabels = list()
      foreach(shap cv
if(shap~>objType == "label" then
allLabels = cons( shap allLabels)
else nil
         x1=car(label~>xy)
         y1=cadr(label~>xy)
         inst=car(dbProduceOverlapInst(cv1 box))
      ) ;foreach
   ) ;let
) ;procedure
发表于 2015-3-2 16:50:58 | 显示全部楼层
推一下!!
GMT+8, 2025-12-26 10:01 , Processed in 0.026631 second(s), 6 queries , Gzip On, Redis On.
